Results 1 to 10 of 10
05-08-2012, 12:58 PM #1
Help, finally failed inspection due to no cats. Options?
So I have Hooker LT's and true duals so no cats. I have the rear o2's deleted from the system. Do you guys recommend a "fake cat" so it looks like I have cats or do I need to put real cats on? theres not a lot of room to work with either. I live in VA. Thanks!
LS6 Engine swap, Custom Predator Tune, Lid, SLP Cold Air, Ram Air H.O. Hood, Hooker Long Tubes, !Cats, 3" True Duals w/Dynomax Bullets, Performabuilt stage 2 w/3600 stall, B&M Trans. Cooler, Moser 12 Bolt w/ 3.73's
Pics of my car
http://community.webshots.com/user/demonspeed_ta
05-08-2012, 01:04 PM #2
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
You're probably going to need to put cats in it. Do they do an actual sniffer test, or plug in to the PCM? Do they inspect under the hood?
05-08-2012, 01:40 PM #3
No Sniffer, not even sure they plug in to the pcm
05-08-2012, 04:12 PM #4
I took my car to get it inspected and it passed. They only did a visual inspection. But I do have high flow cats.
05-08-2012, 04:18 PM #5
- Jan 2009
- North Jersey
If they do visual, get a pair of round cats from Magnaflow, or one of our sponsors. They will fit and you won't get hit with an exhaust tampering fine.
05-08-2012, 04:30 PM #6
How much will it change my performance?
05-08-2012, 04:40 PM #7
- Jun 2011
- Branchville, NJ
I have the SLP high flow cats and I pass New Jersey inspection. Not easy to do.
05-08-2012, 04:40 PM #8
- Jan 2009
- North Jersey
High flows, none.
05-14-2012, 06:40 AM #9
- Jun 2006
- Newnan, Ga
GM LeMans/Luxo Blue- 2001 Firebird Formula
I put high-flow Magnaflows on my Formula and didn't notice a difference at all versus not having cats at all. They are pretty small so they will fit in pretty tight places...the passenger side cat is under the passenger floorboard and the drivers side cat is close to being under the driver's seat. I had them weld in bungs after the cats and put in rear o2 sensors but then had them tuned out by Frost. Works like a charm!
05-14-2012, 12:44 PM #10
- usa
silver- 1924
new cats
Failed Inspection? - Low Mileage Waiver - Texas 2014
By 1stbird in forum Firebird / WS6Replies: 17Last Post: 09-05-2014, 09:01 AM -
By 1stbird in forum Texas MembersReplies: 0Last Post: 08-30-2014, 04:06 PM -
Failed State Inspection need help!
By chiphamons in forum General HelpReplies: 9Last Post: 02-26-2010, 06:35 AM -
OBD system not ready?? Failed Inspection
By 02Hawk in forum Firebird / WS6Replies: 9Last Post: 06-20-2007, 03:18 AM -
No Cats and Passing Inspection
By Tonik in forum External EngineReplies: 3Last Post: 04-02-2006, 03:46 PM
