Results 1 to 1 of 1
05-04-2012, 03:40 PM #1
- Aug 1999
- No Where
351 Cleveland Oil Restrictors - 351C Oiling Fix
Dale Johnson wants the Lowdown on Ford 351 Cleveland Oil Restrictors.Dale Asks:
I'm a little confused about how and when to install oil restrictors on a Ford 351C block. The last time this was referenced (Pit Stop, May '11), you recommended installing oil restrictors in all five main saddles. Moroso has a Ford Cleveland oil restrictor kit (PN 22050) that comes with five plugs: four small (1/4 inch) and one large (5/16 inch). The kit instructions say not to modify the No. 1 main saddle and put the large plug in the No. 5 saddle. Moroso also says "Do not use this kit with hydraulic cams." Should I buy two kits so I have enough plugs for all the saddles, follow the kit instructions, or not install any plugs at all? I have a hydraulic cam with 0.560-inch lift.
Photo Gallery: 351 Cleveland Oil Restrictors - 351C Oiling Fix - Hot Rod Magazine
351 Cleveland Oil Restrictors - 351C Oiling Fix | Digg It | Add to del.icio.us
More...
Help: Top end oiling
By CHEVELLE of JONESY in forum General HelpReplies: 1Last Post: 08-04-2014, 02:17 AM -
Question: 98 Oiling problems???
By ThunderChicken in forum General HelpReplies: 9Last Post: 02-21-2011, 10:02 PM -
K&N Air Filter Oiling
By Banshee1967 in forum General HelpReplies: 2Last Post: 12-22-2007, 09:56 AM -
AC recharge and oiling??
By adham in forum General HelpReplies: 17Last Post: 07-17-2007, 03:17 PM -
LS1 Sump and other oiling parts
By maddog in forum External EngineReplies: 0Last Post: 07-09-2006, 05:00 PM
