Results 1 to 19 of 19
04-22-2012, 03:54 PM #1Member
- Apr 2009
- Pennsylvania
Pewter- 2000 Camaro SS
How Imprtant is a back brace on a 9 inch rear?
Just like the title says. How important is the back brace and why is it there or not there?
04-22-2012, 05:15 PM #2
To strengthen it in HIGH HP applications. I don't have one and I'm at 500rwhp and have been fine. If you plan on going real big, it's added insurance.
04-23-2012, 07:52 AM #3Member
- Apr 2009
- Pennsylvania
Would you need one at 600 HP?
04-23-2012, 08:08 AM #4None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
I would contact the manufacturer of the rear, and ask them. Every brand has a different hp and tq rating, I would guess.
04-23-2012, 10:03 AM #5
From my experience i find it's more a issue of 3 things, weight, power and location of the links, springs, ladder bars in relation to the ends...
If the car has a ladder or link close to the ends of the axle (bearing housing/tire, like it should be) the tendency to bend the housing with big power doesn't usually happen, but move the bars, links, leaf springs in and now you created a leverage effect.
So it kinda depends on a few things, very wide tires massive off set wheels and power and the attachment points are 14" in, brace it
Oh, and don't you brace it unless you have the tooling for it, the housing can and will move and sometimes you will need to reset the ends true to the carrier center line
04-25-2012, 12:55 AM #6
MWC suggests a back brace starting at 550-600 rwhp for their FAB 9.
04-25-2012, 07:17 AM #7
The housings of some companies are LIGHT gauge material to make them weigh less the dana and the 12 bolt
04-27-2012, 06:06 PM #8
04-27-2012, 09:58 PM #9
When I went with the MWC Fab 9 I chose to go ahead with the brace simply because the way the Fab 9 is built, the brace is welded in during assembly. Sure, I'm nowhere near 600hp but the brace is a minimal weight addition for additional room for growth. At some point it becomes a personal preference, really.
2000 Pontiac Firehawk #0041 of 742
04-28-2012, 03:20 AM #10
I don't recall off-hand...what's the added cost?
04-28-2012, 05:22 AM #11Member
- Apr 2009
- Pennsylvania
The back brac is an extra 150. I got a quote from them and for them to ship me everything so I can assemble due to reusing the ABS and traction control they want 4600 dollars. Of course that is with the s track upgrade with35 spline axels.
What did you guys pay?
04-29-2012, 09:03 PM #12
I paid $2500 for my Moser 9" which included new reluctor rings, drain plug, 31 spline axles, housing, third member with 4.11 gears, relocation brackets for the LCA's welded on, and ABS/traction control. It was also painted.
04-30-2012, 05:21 AM #13Member
- Apr 2009
- Pennsylvania
04-30-2012, 09:12 AM #14
Running a PST 3.5" AL drive shaft and a BMR Trak Pak torque arm. Installed the set-up in 2009. Other than an initial axle seal leak I've had zero issues.
Car puts down 500rwhp as of last summer.
Forgot to add, I have the Trutrac center section. Not Mosers strongest set-up.
Some people don't like the torque arm mount on the 9". I haven't had any issues to date though.
Have you looked into the S60?
04-30-2012, 03:52 PM #15Member
- Apr 2009
- Pennsylvania
I receved a quotation for the S60 from Midwest at the same time i recieved the quote for the 9MW and it was only 200 dollars cheaper.
04-30-2012, 04:00 PM #16
Does your price include the drive shaft and torque arm? My DS was $400 and I believe my torque arm set-up was about the same, if not a little more since it's BMR's drag racing torque arm and one of their better units.
04-30-2012, 04:08 PM #17Member
- Apr 2009
- Pennsylvania
Yes it did, it included everything to bolt into the car.
04-30-2012, 05:07 PM #18
Well then that makes the price somewhat more manageable. That would have brought my total up to somewhere in the ballpark of $3400. I'm sure you're being charged a good piece for shipping also.
The MWC fab'd 9" is a stronger unit than the Moser, so you're going to pay more for it.
If I had to do it all over again, I might have got the Wavetrac (lifetime warranty) instead of the TruTrac. Hindsight is always 20/20 though. Hopefully this rear end will hold up. Putting slicks on the car hopefully before year's end to really see what it's capable of at the track. For the more part though, mine is strictly a street car so I feel pretty comfortable with my set-up.
04-30-2012, 05:44 PM #19Member
- Apr 2009
- Pennsylvania
Thanks for your input, i really appriciate it. Looks like i am saving a little bit longer to get the MW9 but i know it will be worth it.
9 inch and rear suspension
By konigandy6 in forum Suspension and HandlingReplies: 4Last Post: 06-18-2011, 08:27 AM -
FAB9 9 Inch Rearend - Baby's Got Back
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 07-01-2010, 02:10 AM -
11 inch rims in the rear
By AKA Speedy in forum Wheels and TiresReplies: 6Last Post: 12-09-2009, 04:04 PM -
Is there a Rear Strut Tower Brace for a Camaro SS?
By 99vetteman in forum Camaro / SSReplies: 4Last Post: 09-28-2008, 01:23 AM -
Rear Shock Spring Bay Brace
By MikeSomething in forum Suspension and HandlingReplies: 1Last Post: 04-11-2007, 01:31 PM
