Thread: Alcohol injection?
04-03-2006, 05:38 PM #1
Alcohol injection?
Anyone have any info on alcohol injection and ltx's?
04-04-2006, 01:43 AM #2
Not for normally aspirated engines...
Many boosted LT1 guys have it and it works very well. Can be used in conjunction with an intercooler, or in place of one.
04-04-2006, 01:13 PM #3
How long does it last? Can you go a whole tank without refilling, or is it only for stress runs?
Reason I ask is that I do plan to go with a blower eventually, but dont plan to properly rebuild for it until I have the money, IE long time
I noticed that alcohol kits are pretty cheap, and i think it would be a good idea to run with 8lbs boost on stock parts just as a buffer against possible detonation and wear/tear with the increased heat. I dont want to bother with 4-6psi, and anthing over 10 doesnt really last very long on stock internals. so i figured maybe 8 with alchy would be a pretty safe deal.
But since I've never done the research, i didnt know weather its even an option... what kind of alcohol is used? alcohols are usually pretty caustic on oils and metals, would it do longterm damage with constant use? or is it even constant, or temporary like a shot of nitrous at high rev points? etc...
thanks!
04-04-2006, 02:04 PM #4If you cant afford to rebuild your motor for a long time, then you cant afford to put a blower on your car. No way around that one...
Originally Posted by grandkodiak
04-29-2006, 09:23 AM #512 Pounds
- Apr 2006
- all over
Silver- 95 Z
i would have to agree my first lt1 lasted a good 9k miles with the blower on it and it was a intercolled one on that. build the bottom end before you get to deep in the wallet it will pay in the long haul
04-29-2006, 03:13 PM #6
can anyone answer my questoin and just pretend its built?
EZ EFI Fuel Injection System - Fuel-Injection Interjection
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 06-06-2013, 06:20 PM -
Alcohol ingestion...
By 67CamaroRSSS in forum Almost Anything GoesReplies: 25Last Post: 02-06-2010, 01:10 PM -
Nitrous/alcohol injection combo
By dogboy in forum NitrousReplies: 1Last Post: 08-25-2008, 11:03 AM -
alcohol creations
By 1MileCrash in forum Almost Anything GoesReplies: 6Last Post: 01-17-2008, 09:13 PM -
Alcohol!
By Mjolnir in forum Almost Anything GoesReplies: 8Last Post: 04-03-2007, 04:16 PM
