Thread: PCV Valve Boot with ground wire?
04-16-2012, 04:29 PM #1
While one a dyne and a tune this weekend after the last two runs I had some blue spoke after the throttle was released. I went to replace the PCV Valve this evening and found it not to be the typical valve location... It is inside a rubber tube with a flange wrapped around it connected to a bracket attached to the block... the boot that held the PCV valve had deteriorated enough that it came apart while pulling the PCV Valve out. No one seems to know where to get this part or what it is.. I have attached a picture. Anyone who has a clue on it would be a huge help! Attachment 23991Attachment 23992Attachment 23993Attachment 23994
04-16-2012, 05:06 PM #2Former Mopar Man
- Jun 2011
- Branchville, NJ
I would try GM Direct or a dealer.
04-16-2012, 05:39 PM #3
The strap is only so that the pcv valve warms up quicker. YOu can buy the whole system for ~$100. Or go to AutoZone, get the new PCV valve with a smaller outlet hole, some fuel hose that fits it, then some bigger hose that fits the other end of the PCV valve, then go to home depot, get a brass barbed tee, soem clamps, and a male adapter. Clamp everything back together. THat is what I did. Here is the post I used as a guide. And screw that strap, unbolt it from the crossover tube, and throw it in the extra parts box. I did.http://www.ls1.com/forums/f6/pcv-val...ication-80151/
04-16-2012, 05:43 PM #4
GM Dealer didn't know what it was or how to begin to find it... Did find this and was the route I was going down.
04-16-2012, 05:43 PM #5
04-16-2012, 08:44 PM #6Electrical Engineer
- Jul 2009
- North of the Motorcity
I would through it in the trash and buy a catch can.
Elite Engineering PCV Oil Catch Can [ELITECAN] - $179.50 : KY SPEED, Performance Parts for Corvette, Camaro, Firebird, GTO, G8, TBSS, Mustang, Challenger, Charger
04-16-2012, 09:46 PM #7
here's a write up on replacing the pcv valve.....the metal strap is actually a grounding strap so that a static spark doesn't ingite the vapors. I personally just removed that strap altogether when I redid my pcv valve.
04-17-2012, 05:13 AM #8
I think for the short term until a catch can is shipped I'm not going to replace the whole system, thats just a waste of useful money towards something else. I have the parts needed to make my own now. However, are there any negatives to a catch can?
04-17-2012, 07:26 AM #9Spaz is My Mentor
none.
These 2 threads are also good reads on another option. Requires a little work, but worth it.
http://www.ls1.com/forums/f6/explain...ct-mod-156010/
http://www.ls1.com/forums/f63/ls6-va...r-pics-145557/
A4 Shifter boot and E brake boot
By JayTA98 in forum Parts For Sale / TradeReplies: 7Last Post: 09-08-2012, 03:50 PM -
Spring Steel Shifter Boot Clip - Boot Champ
By Ed Blown Vert in forum Manual TransmissionReplies: 1Last Post: 08-27-2012, 06:51 PM -
shift boot wire
By bboyish9 in forum Camaro / SSReplies: 4Last Post: 10-15-2008, 09:13 AM -
Need an economical BOOT. Factory boot was stolen
By Herloss in forum ConvertibleReplies: 16Last Post: 05-17-2007, 12:34 PM -
M6 Wire Boot Clip F/S
By Farmer2 in forum Parts For Sale / TradeReplies: 1Last Post: 12-30-2005, 11:07 PM
