Results 1 to 13 of 13
    Mar 2012
    Decorah IA
    Sunset Metalic Orange
    2001 Trans Am WS6
    2001 WS6 Calipers and Rotors
    Looking for a new set of Calipers and rotors for my trans am Would like to keep the price around $1500 or less any Ideas
    Stock calipers are really not all that bad. I just upgraded our braking system with Hawk HPS pads, R1 Concepts slotted rotors and Russell braided lines. World of difference!
    Member flybird's Avatar
    Jun 2010
    Houston
    Mid Night Blue
    1999 Firebird 3.8 series
    There is a guy on here who is selling full set of blue powder coated calipers for $300 I believe. look at those!
    Member Redrokit8's Avatar
    Aug 2011
    Roseland NJ
    Pewter Silver
    2002 Trans AM WS6
    I recently took this same advice from Jeff and got 4 cross drilled & slotted rotors, 4 sets of ceramic type pads as a package from Summit Racing Equipment.
    The parts numbers are as follows:
    Front Rotor & Pad Kit #PWR-K1547
    Rear Rotor & Pad Kit #PWR-K1568
    With shipping it cost me $328.93
    The total shipping and handling cost was only $12.95. Keep in mind that was for a total of 30 lbs.
    The brand name is Power Stop. Yes, they are made in China but appear to me to be of very good quality and certainly much more smooth than the factory brakes which only had 12K on them.
    Make sure to follow the 10 minute break in procedure and you'll be impressed.
    Also make sure you purchase synthetic brake grease and and lube all points, especially the pins which will come out very dirty. I agree that the calipers are satisfactory for most uses. PM Jeff and ask him for a picture of the calipers he refinished in the stock color of silver.
    I'm sure I was just dreaming this, but braking with reasonable pressure from, let's say, over 120mph there were no issues, no pedal vibration etc. Thank God it was only a dream. Driving like this on our interstates is considered irresponsible.
    Also Jeff's advice for braided lines from Russel, from Summit as well, will stiffen and firm up your pedal pressure. The stock rubber hoses expand under pressure and make for a softer feel.
    Go for it. You are wise to address the brake issue.
    Magnaflow Quad Tip, Lid, SBellow
    UMI: FTC, FSB, RSB, LCA's, PBAR, SFC's, T-Arm w/relo, D/S Loop
    Kooks LTH, 3" YP, H/F Cats
    Custom Grind Cam, Stall, 3:73 rear
    Bilsteins w/Strano Springs Conti Super Contacts
    TuneByFrost MSD Wires
    Cross Drilled/Slotted Rotors w/Ceramic
    Apr 2010
    Alabama
    Black/ Silver
    98 TA WS6/ 01 C5 Corvette
    Or this:
    Cost me less than $600 but if you don't have 18" or bigger wheels then it won't work so the other route others have mentioned would be a better idea in that case.
    1998 Trans Am WS6 - Phantom
    421 LQ9 14.8:1 on E85 Build/
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    He's a third option: UMI 93-02 GM F-Body C5 Brake Conversion Kit - With Slotted Rotor [2120B2] - $989.99 : KY SPEED, Performance Parts for Corvette, Camaro, Firebird, GTO, G8, TBSS, Mustang, Challenger, Charger
    C5 conversion kit for just under $1000. Includes hawk pads. I would also do what Jeff did and upgrade to steel braided lines.
    Mar 2012
    Decorah IA
    2001 Trans Am WS6
    Thanks guys that helped out alot!!!!!! Now just gotta find new rims and tires
    **Te@M fBoDy** fbodyNATION's Avatar
    Nov 2010
    The Woodlands,Texas...N.O.
    Pewter Metallic
    2000 Pontiac Trans Am WS6
    I was thinking about upgrading my brakes also,should i start with the hoses first,i already have slotted rotors,i have to get some for the rear now,but how much does a set of braided brake lines cost roughly?
    phoenix
    04 2500 4x4 crew cab
    That is going to be on my list. Thanks, jeff
    Note that the orientation on the front brake lines will be different than stock.
    Mar 2012
    Decorah IA
    2001 Trans Am WS6
    Even tho I dont need new calipers what would work good with with the rotors and pads you suggested earlier jeff?
    I am using my stock calipers. No complaints with the rotors and pads -- pulls her down nice at the top of the track and I have zero fade.
  1. Anyone put front calipers & rotors on rear??
    By COKEBOTTLES in forum Suspension and Handling
    Last Post: 08-01-2009, 07:47 PM
  2. Pewter! Painted Calipers & Rotors!
    By Bouvers in forum Appearance Section
    Last Post: 08-17-2008, 08:34 AM
  3. looking for upgrade on rotors and calipers
    By ws62002 in forum Suspension and Handling
    Last Post: 04-16-2007, 07:15 PM
  4. changing rotors and calipers
    By GottaHaveLS1 in forum General Help
    Last Post: 12-23-2006, 10:13 PM
  5. New rotors/calipers
    By doubletimebluz in forum General Help
    Last Post: 05-10-2006, 04:15 AM
