Results 1 to 3 of 3
    Don't Listen to Me NE98LS1's Avatar
    Nebraska
    removing center plastic piece
    i need to remove the plastic covering that is part of the lower console and goes all the way back to the arm rest, and goes around the shifter on an automatic. the problem is, the slot where the shifter moves back and forth is not wide enough to get over the grip part of the shifter, anyone know how to get this plastic piece off?
    Junior Member 2000SS4273's Avatar
    Ohio
    Bright Red, Victory Red
    00 Camaro SS, 07 Corvette
    Removing the shift lever handle
    To remove the handle, you need to locate and remove the metal clip that pushes into the handle. It should be located on the side facing the dash at the base of the handle and can be removed with a small flat blade screwdriver. Be careful to not lose the clip. I hope this helps!
    Nebraska
    thanks man, i didn't even look around for that, but i'm sure you're right, i have to cut that piece with a dremel to install my satelite radio where i want it
  1. Question: lighting up center piece on back end
    By izzhemp in forum Firebird / WS6
    Last Post: 10-30-2009, 08:04 PM
  2. Plastic seatbelt piece passenger headrest
    By Hurley711 in forum Parts Wanted / Trade
    Last Post: 07-05-2009, 07:17 PM
  3. Need radiator plastic cover piece. ASAP!
    By 01SOMSS! in forum Western Members
    Last Post: 05-23-2008, 03:56 AM
  4. 2000 camaro ss convertible (3 piece plastic covers)
    By 70ssrag in forum Parts Wanted / Trade
    Last Post: 03-30-2007, 07:44 AM
  5. Blacked out center piece
    By RAWPWR3 in forum Firebird / WS6
    Last Post: 01-31-2006, 04:15 AM
