Results 1 to 3 of 3
04-08-2012, 12:37 PM #1
- Apr 2012
- virginia
blue- 2001 trans am
looking at valvetrain suggestions
looking at rocker arms, push rods, possibly springs and retainers. not looking to pull the cam yet my experiance is not the best but it seems rocker arms are bolt on, im thinking comp camp or yella terra... pushrod legnths? any performance gains from this?
04-10-2012, 04:24 AM #2
- Dec 2005
- Laurel, Maryland
Why are you doing these upgrades if your not upgrading your cam? Seems kind of pointless unless you're nearing 200k miles, and even then I don't see the point. I have a friend who is over the 200k mile mark in his 1998 Camaro SS with a completely stock motor, clutch, trans, and rear.
To answer your question...Trunion Upgrade for the rockers, 7.400" (stock length) Hardened Pushrods, and LS6 Springs. Retainers are one of those "non-wear" parts that do not need to be replaced, but if you insist, you can pick them up from GM for super cheap...$2 each I think. If you're repacing the retainers, you might as well replace the valve locks as well.
The only performance gain you'll see is from lighter rocker arms (Yella Terra), but I still don't see the point of spending $400 for aftermarket rocker arms on a stock motor. The gains will be minimal, if there are any at all.
04-11-2012, 06:46 AM #3
- Aug 2011
- Browns Mills NJ
Green- 1995 Z28 w/ LS1 Swap
IMO thats a lot of work and no point to do any of it without upgrading the cam
Heads/Cam/Intake/Stall.
404 Rwhp uncorrected @ 6400
Ls6 cam n valvetrain
By 69PONTIAC in forum Parts Wanted / TradeReplies: 0Last Post: 04-04-2010, 12:24 AM -
Help: valvetrain help?!?
By WSICK in forum Internal EngineReplies: 21Last Post: 09-04-2008, 06:41 PM -
It's Not the Valvetrain... What Else?
By Sizzlenut in forum Internal EngineReplies: 11Last Post: 02-04-2008, 08:26 AM -
Valvetrain
By apollyon_01 in forum Internal EngineReplies: 2Last Post: 12-19-2007, 04:53 AM -
C5 Valvetrain
By apss in forum Parts For Sale / TradeReplies: 0Last Post: 01-10-2007, 10:30 AM
