Results 1 to 11 of 11
    Apr 2012
    new haven, Mi
    red 93' nbm 02'
    1993/2002
    just saying HI, im back in the game
    been out of it for some years...job family etc but im back now just got a 2002 35th anv Camaro plans are to swap in my Lt1 i have from my old car hope it pans out.
    Welcome, Dennis. So, you're saying that you are planning on swapping out the LS1 in your 35th Anny for an LT1? I have to ask why...
    Welcome back! Curious on the reason for the swap.
    Nov 2009
    Jacksonville FL
    TRIPLE BLACK
    2000 CAMARO SS M6 #2100
    Don’t think you guys caught that he didn’t mention the terms Z28 or SS therefore he most likely has a V6 and plans to swap in the LT1. Anyway, welcome to the site man!
    I was unaware that there were any 35th anniversary packages on the V6... Just the SS.
    Pittsburgh
    2008 Hummer H3
    +2.. I know the 1992 25th anni's came in either v6 (3.1L) or v8, but did'nt think the 35th's did.
    OP, Welcome to LS1.com!
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Maybe he has a built LT1. I would not swap an LS1 for a LT1 unless there was an advantage. Let's see what he posts.
    Nov 2009
    Jacksonville FL
    TRIPLE BLACK
    He never said 35th edition or package. If my memory serves me correctly, all 2002 Camao’s including the base models came with that little dash plate that said 35th anniversary Camaro on it. I may be totally wrong though and he may be pulling an LS1 for an LT1 but to me there is zero reasoning behind that swap which brings me to believe that he is talking about a V6. Maybe he will chime in here and let us know.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    My guess is he means 35th anniversary model which is all 2002's and not the Limited Edition (LE), which as Momma stated, is indeed only optioned as such on the SS model and looks identical to my car found in my avatar.
    Waiting on the Tree transamtom's Avatar
    Niagara Falls Ont.Canada
    1999 TA A4
    Welcome,your swap will not be easy if you go LT1.
    Its going to be harder to do an LT1 as the wiring harness is set up for the 3.8L and LS1 platform.
    You will also need an LT1 K member or aftermarket tubular one and a LT1 tranny as it has a different input shaft.
    You will need to do a 24x PCM conversion to make the LT1 work with the 2002 harness.
    I think You should sell the LT1(JMHO FWIW) and pick up either a 5.3L or 6.0L truck engine with trans or try to find an LS1 w/trans which may be harder to find and pricier.
    You will still need an LS K member or aftermarket tubular.
    Good Luck which ever way you decide to go.
    2010 Camaro SIM 2SS/RS A6
    1999 TA A4 NBM
    12.265 at 110.52mph
    Hopefully, Johnny comes back soon to clear it all up
  1. Back in the game
    By LoveSpeed1 in forum New Member Introductions
    Last Post: 12-01-2012, 09:40 AM
  2. Im back in the Game!
    By BadBlueBird* in forum Member's Rides
    Last Post: 08-03-2011, 05:06 AM
  3. Trying to get back in the game
    By MawkViper in forum New Member Introductions
    Last Post: 06-17-2011, 06:57 AM
  4. back in the lt1 game
    By 94jonnyb in forum New Member Introductions
    Last Post: 02-13-2009, 04:23 PM
  5. Back in the game...
    By Superz in forum Rocky Mountain Members
    Last Post: 07-17-2008, 07:06 PM
