    Drop&Drag matt evans's Avatar
    clyde nc
    02 Z28 and 00 SS
    Installed line lock and now have abs light on???
    I just got back from a ride in my 02 Z after getting the slp line lock installed and putting the welds on as well. going down the road my abs inop light and brake light comes on. Cut the car off the lights reset but after a few minutes they pop back on. Could air in the lines cause this or could it be a bad sensor? I havent tried putting my 18s back on but thats the next thing im going to try.
    clyde nc
    02 Z28 and 00 SS
    Throwing code co245
    2002 Camaro Z28, A4, MS4 cam, underdrive pulley, Pacesetter LTs with ORX true duals
    2000 Camaro SS, M6, SLP LTs with ORX true duals
    Hmmm. Had zero issues with mine after installing it. What is the height difference between your front and rear tires?
    clyde nc
    02 Z28 and 00 SS
    fronts are about 24in and the back are 28. im thinking i have air in the front because the line lock had a leak and i had to loosen the lines up. Never bled them back out.
    The tire diameter difference is the problem. The wheel speed sensors see this as a huge difference and think that your car is either slipping, or that the system has a fault as it is continuous. Stick your other tires back on the car, unhook your battery for a few minutes (or simply drive the car for a while) and then see what happens.
    clyde nc
    02 Z28 and 00 SS
    ill try it today. Hoping to get to the track this evening to see if we dont get faster on the slicks. Did a test launch last night and it never hooked that good before on the street.
    I agree with Jeff..... 4" is a pretty substantial difference in height. I would want to make damn certain those brakes are bled out though before taking it to the track.
    clyde nc
    02 Z28 and 00 SS
    im going to do that in a few. Its hard tho when you dont have a extra set of hands. People like to use the shop for there own cars but when it comes time to help they bail.
  1. Installed SJM ABS delete and line lock (pics)
    By derekbuckner1 in forum Drag Racing
    Last Post: 09-17-2012, 11:52 PM
  2. who has installed an slp line lock?
    By 0rion in forum General Help
    Last Post: 04-02-2009, 03:16 PM
  3. Line Lock installed pics
    By 01WS6475hp in forum General Help
    Last Post: 08-11-2008, 03:11 PM
  4. Replies: 56
    Last Post: 04-24-2008, 05:24 PM
  5. Line lock/ brake line ?
    By 2001z in forum Suspension and Handling
    Last Post: 04-01-2007, 05:42 AM
