Results 1 to 3 of 3
Thread: 228r cam install random ticking
04-03-2012, 07:33 AM #1Member
- Jun 2008
- michigan
black- 1998 trans am
I installed a 228r cam, with new hardened pushrods, spring, seals, oil pump and timing set. I have a random ticking noise when at idle in drive (like parking in a lot). Noise sounds a lot like a quiet exhaust leak, it doesn’t speed up with rpm seems to go away after 2000 rpm. I have rechecked the valve train twice; I’m using the ls1 how-to install.com method, just torque to 22ft and turn 180 check torque. The noise seems to be random once engine is over 150F, sometimes it’s there sometimes not. Should I ignore it, install valve train with a tdc method, or tear it down and replace lifters. Don’t mean to be freaking out maybe I’m being paranoid. Car runs awesome other than noise.
04-03-2012, 08:08 AM #2
I would have to hear it.....is it more of a sewing machine type noise? That'd be a normal sound.
08-06-2012, 03:04 AM #3Member
- Jun 2008
- michigan
Just a quick fellow up on this, so it doesn’t set unresolved like so many forums.
I measured my preload with a dial indicator and found that I only had .050 preload. I installed .0250 longer pushrods (7.425) valve train sounds like stock much much better. Not saying this will fix everyones problems but measure preload.
Question: Ticking noise after Cam Head install
By 1slowbusa in forum Internal EngineReplies: 24Last Post: 01-11-2015, 04:33 AM -
Ticking after header install
By afattitude in forum External EngineReplies: 26Last Post: 03-10-2009, 11:26 AM -
Engine Ticking After Head and Cam Install
By Eddie 70 in forum Internal EngineReplies: 13Last Post: 01-28-2008, 04:50 PM -
Loud ticking noise after cam install
By gunguyWS6 in forum Internal EngineReplies: 8Last Post: 11-01-2007, 04:05 PM -
slight Ticking noise after intake install
By ViperSniper in forum General HelpReplies: 1Last Post: 08-27-2007, 11:47 AM
