Results 1 to 20 of 27
Thread: GMpartsdirect.com oil pan
04-01-2012, 10:13 AM #1
I need a new oil pan, and GMpartsdirect has them for cheap. has anyone bought one from them? I'm supposed to verify my VIN, but they havent gotten back to me in 3 days and i have NO car.
04-01-2012, 01:36 PM #211 years of bangin gears
- Jan 2009
- North Jersey
Have you contacted them since? I would.
04-01-2012, 02:02 PM #3
Only form of contact is email. It's how they "keep costs down"
1998 Z28: Bolt-ons, Stage ? 4L60E. 250rwhp@6500Ft (R.I.P 5/1/2013)
1998 Mystic Teal Trans Am: Bone stock. (In process)
04-01-2012, 02:45 PM #4Former Mopar Man
- Jun 2011
- Branchville, NJ
You can find OEM pans online with fast shipping. I would not wait for GMpartsdirect.
04-01-2012, 02:53 PM #5
Yeah i was looking at summitracing.com. Ive had good experiences with them. But they're 100 more. What do you guys think about aluminum welding?
04-01-2012, 02:58 PM #6Senior Member
- May 2010
- Wilkes-Barre, PA
Black/Black- 98 WS6/04 Sierra Dmax
What is wrong with your oil pan? I'm sure if you take it to a machine shop they could fix it up for you. When i had my engine apart some how the corner of my oil pan where the bolt hole is cracked off. The engine shop just welded it back on. Can't even tell where the crack was.
04-01-2012, 03:02 PM #7
04-01-2012, 03:06 PM #8Senior Member
- May 2010
- Wilkes-Barre, PA
Looks like it could be fixed. Would definitely be the cheapest route.
04-01-2012, 03:54 PM #9
My brother is taking it into his work to see if one of the mechanics can weld it.
04-01-2012, 05:44 PM #10Former Mopar Man
- Jun 2011
- Branchville, NJ
I would not mess around with something as important as your oil pan. This is not a water pump your dealing with. A failure of the pan while driving could cost you an engine. Penny wise and pound foolish is not the way to go. Suck it up and do it the right way, buy a new pan.
04-01-2012, 06:11 PM #11Senior Member
- May 2010
- Wilkes-Barre, PA
I don't understand what could fail if it was welded correctly.
Callies 383, Trick Flow 225, Rapid Motorsports Dominatior 2 X cam, ls6 ported oil pump,42lb injectors, FAST 92/92 , ASP underdrive pully, eletric water pump, Pacesetter LT's, Pacesetter ORY, Magnaflow catback, e-cutout, Yank SS 3600, Performabuilt stage 2 4l60e, Strange S60 ,4.10s, Detroit Truetrac, (UMI) - Adj. LCA, Adj. tunnel mount torque arm, Adj. panhard bar, Drag bar, subframe conectors, shock tower brace. 465rwhp-438rwtq [email protected].
04-01-2012, 06:59 PM #12
I'm not worried about buying a new one, but if it can be fixed why waste the money.
04-02-2012, 03:56 AM #13
04-02-2012, 07:16 AM #14
Are all ls1 car oil pans the same? As in swappable without changing anything?
04-02-2012, 12:13 PM #15Spaz is My Mentor
All LS1 Firebird Formulas/Trans Am/Camaro's are the same. LS1 Corvette/GTO's are not the same style of oil pan.
I've ordered parts several times from gmpartsdirect. For OEM parts they have some of the best prices. I've had only one issue and it really wasn't their fault. I tried getting a new bell housing for M6. GM quit making them just prior to me making my order. They let me know and refunded my money.
04-02-2012, 02:25 PM #16
Thanks. local sale was for a front sump. He didn't know.
The local performance shop turn me onto this gem. Part #:19212593. Summit carries them for $150. Guy swears by it, so hopefully it works.
04-02-2012, 02:48 PM #17
As long as dimensions are maintained, I would not hesitate to repair the stock pan.
04-02-2012, 02:54 PM #18
04-02-2012, 03:34 PM #1911 years of bangin gears
- Jan 2009
- North Jersey
Keep us updated.
04-03-2012, 04:15 PM #20
Oil pan came it. It's lighter, stronger. lined up perfect. doesn't have a provision for the oil level sensor. It came with a new pickup tube, windage tray, hardware, gasket, and dipstick. Had the felpro gasket, so the other came off. i had to use the new pickup tube, and windage tray, but it bolted up great. had an injury, so i haven't gotten to run it yet, just waiting on the oil, and putting the cross member back in.
LS& clutch kit from gmpartsdirect
By 99RedTa6spd in forum DrivetrainReplies: 6Last Post: 12-09-2011, 01:43 PM -
GMpartsdirect.com
By 19691998firebirdtransam in forum Sponsor FeedbackReplies: 21Last Post: 10-06-2009, 09:42 AM -
GMpartsdirect
By Y2KPewterSS in forum Sponsor FeedbackReplies: 3Last Post: 04-17-2008, 06:16 PM -
GMpartsdirect.com : thank you.
By djvaly in forum Sponsor FeedbackReplies: 3Last Post: 12-09-2007, 02:48 PM
