03-29-2012, 03:06 PM #1
noise after i floor it past 3500rpm
First T/A that i own, ive had it for 2months and ive notice that everytime i rev my engine past 3500rpm i hear it a "strange" noise for the rest of the ride...its up front not sure where its coming from but it gets louder as im making a turn.
is this normal??
03-29-2012, 03:53 PM #2Electrical Engineer
- Jul 2009
- North of the Motorcity
Is it consistent with speed or Rpm?
03-29-2012, 06:50 PM #3
Rpm, im new to this car so im not sure how to narrow it down.
03-29-2012, 08:00 PM #4
Have you checked your power steering fluid?
03-29-2012, 08:02 PM #5
Last time i checked it was 2000miles...will check it again
03-29-2012, 08:03 PM #6
Rev it up till it makes noise and check if the fluid has bubbles. Happened to me in my 94 cuz air was getting sucked in
03-29-2012, 08:19 PM #7
Its a purring noise, as if the engine was working to hard...not sure
But thanks il check it out tomorow when i get the chance. Makes sence though
03-29-2012, 08:46 PM #8Electrical Engineer
- Jul 2009
Check your belts for wear. See if you tell its coming from a specific pulley, one of them could be going bad.
03-30-2012, 01:49 AM #9Senior Member
- Nov 2006
- Indianapolis
+1 on PS fluid being low.
04-01-2012, 09:21 AM #10
Thanks everyone...this site can save a lot of money and time... GREAT
04-02-2012, 05:47 AM #11Senior Member
- Nov 2006
- Indianapolis
Now. Where did the fluid go? Check your rack and pinion. The hoses start leaking as they get 12 years old also.
04-02-2012, 03:37 PM #1211 years of bangin gears
- Jan 2009
- North Jersey
Check the bellowsas well. The rubber boots on the rack can collect p/s fluid when the seals fail. Poke a small hole in the boots and see if any fluid drains out. If you see fluid, there's your leak.
Tom Clancy Past away
By SMWS6TA in forum Almost Anything GoesReplies: 5Last Post: 10-02-2013, 05:10 PM -
past and present
By jdcws6 in forum Member's RidesReplies: 4Last Post: 06-04-2012, 08:41 PM -
this past Christmas
By cuervo25_1 in forum Almost Anything GoesReplies: 7Last Post: 02-04-2011, 08:25 AM -
Help: weird noise when putting it to the floor.
By mikemurray13 in forum Camaro / SSReplies: 9Last Post: 10-14-2008, 12:08 PM -
Just got it this past weekend
By turboz28 in forum Member's RidesReplies: 18Last Post: 12-13-2007, 07:40 AM
