Results 1 to 11 of 11
    Oct 2009
    The Woodlands/spring/houston
    pewter
    99 trans am
    anyone using this gasket?
    just wondering if this felpro pan gasket would be a bad decision over stock style.
    Felpro/Oil Pan Gasket (1839) | 1999 Pontiac Firebird 8 Cylinders G 5.7L SFI | AutoZone.com
    Oct 2009
    pewter
    99 trans am
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Felpro makes a quality product. I would not have a problem with using this gasket
    That doesn't look anything like the gasket on our car -- more of a SBC looking part than LS1 if the representation is accurate. The stock gasket is dead soft aluminum with a neoprene sealing bead.
    Oct 2009
    pewter
    99 trans am
    i also thought that too jeff...but ive read somewhere that felpro made those as multipiece gaskets and some people use rtv on them to help seal.
    Coral Springs, Fl
    Sunset Orange Metalic
    First i've seen that
    Mine looked like jeffs, I actually think i have a spare one laying around if you want a GM one
    Even with the stock GM gasket, you need to apply a dab of RTV at all four corners in the area where the front and rear engine covers mate with the block.
    Oct 2009
    pewter
    99 trans am
    wish i would have known earlier this week. i plan on putting the engine back in this weekend. guess ill buy the one that looks like what jeff posted...autozone is stupid to post a picture for the gasket that looks nothing like the origional.
    Oct 2009
    pewter
    99 trans am
    also, do i need to worry about putting rivets back in?
    Nope. The factory service manual states that the rivets do not need to be reinstalled. You can run a couple of bolts up through the pan and into the gasket to hold it in place as you place the pan in position. The holes in the gasket are small enough to securely hold the bolts.
    Oct 2009
    pewter
    99 trans am
    i keep forgetting that i have a gm parts and service guide..check it out... http://127.0.0.1:9001/servlets/Home?app=SI ...im not sure if it will work for anyone without the disc though....
  1. STS blown head gasket?? What head gasket
    By 2000sts in forum Forced Induction
    Last Post: 08-26-2009, 02:23 PM
  2. oil pan gasket
    By caravello510 in forum General Help
    Last Post: 08-10-2009, 04:02 PM
  3. Oil Pan Gasket
    By 00 formula in forum External Engine
    Last Post: 03-30-2009, 05:54 PM
  4. Oil pan gasket
    By Danger731 in forum Western Members
    Last Post: 08-16-2008, 07:53 PM
  5. gasket?
    By andybcrazy in forum External Engine
    Last Post: 08-14-2008, 04:29 PM
