Results 1 to 3 of 3
    white stallion soljhaboy2c's Avatar
    tacoma, washington
    1998 pontiac trans am
    need help matching parts!!!!!
    i already have these parts in my possession, comp cams hydraulic roller lifters, comp cams 277/281 extreme cam, fast 90mm intake and tb, with fast fuel rails, ls6 heads stage 1 ported, and comp cams roller rockers. i just need some feedback on whether or not the stock valvetrain will work with this setup before i go and throw all of this stuff in next week. someone help me out please. oh my the way its all going in my 98 trans am, ls1, 6 speed auto.
    tacoma, washington
    ok the cam is 224int/228exh @ .050, 112 sep. .534int/.537exh valve lift
    Senior Member Redphoenix1998's Avatar
    Apr 2002
    San Jose
    1998 Pontiac Trans Am
    Get a set of matched hardened pushrods, when assembling the motor, find out the length and buy the right set. THe stockers will bend and break. Also look into a set of comp 918 dual valve springs, always a safe bet. You'll also need at least a 255 fuel pump and 30# injectors with some good tuning to get the power from this cam.
  1. Question: Paint matching?
    By K_garretson23 in forum Appearance Section
    Last Post: 08-29-2011, 10:13 AM
  2. Stock paint not matching?
    By ReSSurected in forum Appearance Section
    Last Post: 08-03-2008, 07:25 PM
  3. Color matching
    By lovemybadkitty in forum Firebird / WS6
    Last Post: 12-25-2007, 02:32 PM
  4. Matching jets...
    By Liveforfunjim in forum Nitrous
    Last Post: 09-27-2007, 06:09 AM
