Results 1 to 11 of 11
    Apr 2009
    tn
    msd opti prob help please
    I just installed a msd opti on my 93 lt1. I set the timing two turns out as recommended by msd. It will turn over and will not crank. It sometimes trys to. Now if i run the timing screw all the way in it will crank rough and run but back fires thru the tb. I have run it all the way in and out 1/4 turn at a time and it will not run right. This is a brand new unit. Does anyone have any ideas?
    Member krese's Avatar
    Feb 2008
    Brewerton, New York
    1996 Trans AM WS6
    yeah, get an OE opti
    did you make sure to check all your wires?
    Apr 2009
    tn
    Yep, pulled the msd off and put the stock one back on and it run fine. Removed it put msd back on and same problem. Im puzzled.
    Oct 2001
    Colorado
    95 Z28
    I didnt think people usually had problems with the MSD unit. Return it and try another MSD, but if you have the same issue again it likely isnt the MSD opti causing the problem.
    Feb 2008
    Brewerton, New York
    1996 Trans AM WS6
    there have been countless instances of people having issues with MSD units. most LT1 forums say to just get the OE opti and be done with it.
    Apr 2009
    tn
    Quote Originally Posted by 5.0THIS View Post
    I wouldnt think it was the msd either, but it runs fine with the stock unit. Tried it again bout an hour ago.
    Apr 2009
    tn
    Quote Originally Posted by krese View Post
    The more I read seems there are several problems mentioned. None of them match my findings though.
    Oct 2001
    Colorado
    95 Z28
    Well there ya go then.
    To the OP, why are you replacing the OEM unit if it's working fine?
    Apr 2009
    tn
    Sorry should have been more clear. I bought the car with seller saying it was the opti that was bad. I didnt want to spend a bunch of money to find out it was something else so i bought one of the 99 dollar remans off e-bay. After seeing that was the problem I bought the msd. I dont trust the ebay opti. It may last forever but dont want to chance it.
    Jun 2012
    pearl river, La.
    1999 trans am ws6
    Hi. I will tell you about my msd opti spark issues. My car had a cheap ebay opti. I restored my car and engine was rebuilt also with every sensor, etc replaced. Everything worked fine for about a year. Opti went out. No water issues, just junk opti i thought. Bought msd and installed. lasted 2 yrs 2 months. Not a everyday car. opti had about 3000 miles on it. then out blue it started with typical opti issues. Removed it and sent it back to msd. I asked if they were able to test it before they did any work on it. they said yes. They said they tested it and said it was bad. They rebuilt it and sent it back. Still no crank. Called them back and talked with different people each time. Finally was told that they lied and they cannot test the opti. they just put all new parts in it if it comes back and good luck.. Well the problem come to find out was there MSD coil. it developed a crack in it for no reason. Talked with another lt1 guy and he had problems with msd coil also just like mine. SO all this trouble of swapping opti sparks numerous times was due to there junk 1 yr old coil. I was told by couple guys to only run stock coil. as far as msd opti.. I will never buy anything with msd name on it.I also have a brand new liftime opti spark sitting in a box i bouht due to running out of options with msd tech line. The msd coil was still providing spark to plugs.. just would not run... Not long after i said screw it and sold car and bought a ls ta.
    Oct 2001
    Colorado
    95 Z28
    I ran an MSD coil for years with no issues. Alot of times there are other issues that can cause component failures. But that's not to suggest that an MSD couldnt be bad.
  1. pcm prob i think
    By jasonarthur in forum Computer & Tuning
    Last Post: 04-09-2011, 07:00 PM
  2. now she wont even run, opti prob?
    By ggino85 in forum LT1
    Last Post: 10-05-2009, 04:58 PM
  3. oil pressure prob?? (see vid)
    By Z28boy2000 in forum Internal Engine
    Last Post: 09-24-2009, 08:49 PM
  4. shift prob.
    By m1083 in forum Manual Transmission
    Last Post: 08-13-2006, 01:07 PM
  5. a/c prob help!!!!
    By larryndog in forum General Help
    Last Post: 07-25-2006, 01:17 AM
