Results 1 to 2 of 2
    Member IH8EVRY1's Avatar
    Apr 2010
    Savannah, GA
    Tires scrubbling/worn out shocks - Recomendations?
    I think my shocks are just worn out. The car has 120K miles and the original shocks. I removed my bump stops when I put 17x11s and 315/35R17s on the car. Originally I had no issues but recently, dips/bumps/bridges/etc at higher speeds (55+ MPH) the tires contact the inner lip of the quarter panels. It happens more on the passenger side than the driver side but it does it on both.
    I've checked all the bolts and nothing is loose. Aside from adjusting which hole my LCAs are installed in the relocation brackets, I think it's time to get shocks. Unless anyone can recommend something else I should check.
    Can anyone make a recommendation on rear shocks? I don't really care about stiff ride quality. The car is street driven but drag race set-up is my desire.
    I've looked at KYB AGX Adjustable and Koni Adjustable shocks from sponsors but I'm open to any suggestions.
    Y2K SS A4 Y2Y GU5: 12.96@106-SLP FLO PAC|P&P Stock TB | Pacesetter LT's | TSP Rumbler X Duals | B&M Trans Cooler | Rear Tubular LCA's w/ Relocation Brackets | Tubular PHB | SFC's | Diablo Sport Tuning
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    Yep your shock are overdue I actually went back to stock suspension recently because I had worn out my bilsteins An adjustable pan hard rod will help even that scrubbing your getting but with those wide tires you should grind or roll the fender. Qa1's are popular for drag racing but they are probably a little more than the agx's. Taking out the bump stops is all bad if you ever bottom out-especially in a turn. I know it sounds white trash but if you have aftermarket springs that are tightly wound (hotchkis for one) tennis balls make a good substitute for bump stops. They don't work so well in my strano's but in the hotchkis you can put 3 in at a time and make a progressive spring out of them-don't go nuts with them but some experimentation leads to some good results.
  1. radiator recomendations
    By dpinson in forum External Engine
    Last Post: 07-20-2009, 11:30 AM
  2. recomendations for headers 02 ta?
    By ws6_ls1_209 in forum External Engine
    Last Post: 06-17-2009, 04:26 AM
  3. Recomendations please
    By Ikillmustangsw/myZ32 in forum Firebird / WS6
    Last Post: 07-24-2008, 08:53 PM
  4. Posi rear's are fun with worn tires
    By 98-LS1 in forum Drivetrain
    Last Post: 10-03-2006, 01:41 PM
  5. worn out shocks and spings....traction
    By In_style in forum Suspension and Handling
    Last Post: 11-05-2005, 03:13 AM
