    Feb 2012
    Memphis
    2001 Trans Am WS6
    HELP! my car wont stay cranked in 1st gear!
    For some reason my car trys to quit on me when i am in first gear... i went to autozone and got them to run a diagnostic and it showed that my coolant temperature was low. I got my fluids checked out and the guy said it might be the sensor? I went to a shop and they told me lack of compression sense im running from the heads with little pipe(thats what she said /ba dum tsssss) and no mufflers. Also he said it might be because of the cam buuuut this was all speculation from just taking a glance at it... Then when i brought the car home and lifted the hood i could hear a small hissing noise that lasted about 5 seconds and stopped. Please help!!!
    Member chris1974's Avatar
    Jan 2012
    Houston
    Bright Red
    1998 Firebird Formula LS1
    what mods have you done to the car?
    Feb 2012
    Memphis
    2001 Trans Am WS6
    ceramic longtube headers, cam, custom tune, comp cam valve springs and retainers, hardened pushrods, etc etc
    Member damianj03's Avatar
    saint robert, mo
    slap your mama red
    1998 trans am
    hissing while it is running or off? have you checked for vacuum leaks?
    Member Goldcuffs's Avatar
    Aug 2008
    Florida
    2000 Trans Am
    A "coolant temp low" code usually pertains to a thermostat problem. Do you have a lower than stock thermostat installed? Regardless, this will not cause what you are experiencing. Autozone uses a generic scan tool and in my opinion is useless. With out a screen shot of data or fuel pressure readings, or some kind of info, everyone that posts here will be guessing. If you took it to a shop and they said compression just by looking under the hood, you might want to just stay away from that shop.
    Could also be a defective temp sender that is causing the PCM to think that the engine temp is lower than it actually is. This would leave the PCM in open rather than closed loop and could account for your issues.
    Coral Springs, Fl
    Sunset Orange Metalic
    Jeff makes a good point
    Temp sensor is cheap enough to just swap out, I'd see if that helps.
    Feb 2012
    Memphis
    2001 Trans Am WS6
    Thanks for all the help!
    @damian, it was a vacuum! So out of curiosity would the sensor affect the not staying cranked in first? it doesnt do it everytime but often enough to be an annoyance.
    Coral Springs, Fl
    It's enough to cause misfires our poor performance. I had issues similar and part of it was a bad pigtail on the harness for the coolant sensor
  1. Help: Wont stay running
    By hetman1 in forum General Help
    Last Post: 06-03-2026, 12:10 PM
  2. Question: car wont stay runing
    By bvar20 in forum Firebird / WS6
    Last Post: 04-04-2014, 04:20 AM
  3. Question: It wont stay!
    By Ws66 in forum Appearance Section
    Last Post: 12-19-2011, 08:11 AM
  4. Help Trans am wont stay on
    By LS1_ws6 in forum Firebird / WS6
    Last Post: 07-26-2011, 05:38 PM
  5. Question: Hatch wont stay up
    By izzhemp in forum Firebird / WS6
    Last Post: 12-12-2010, 11:11 AM
