Thread: BBK Fuel Rails
02-21-2012, 02:55 PM #1Junior Member
- Sep 2008
- Corpus Christi, Texas
White- 1999 WS6 30th Anniversary
BBK Fuel Rails
I purchased the BBK Rail Kit #5018 for my stock 99 WS6 TA.
The passenger side rail went on ok but the drivers side rail and crossover is hitting an L shaped braket at the back of the intake.
The bracket I'm referring to is connected to the intake manifold by two bolts (manifold bolts) and a small wiring harness is attached to the bracket.
My question is whether the bracket can be removed and will I have any problems removing two intake manifold bolts and then reinstalling them?
Thanks
02-23-2012, 08:04 AM #2Spaz is My Mentor
Are you referring to the bracket that holds the throttle body cable and cruise control in place?
If so, then yes you'll have a lot of difficulty in just removing those 2 bolts. The only way you can get them out is by removing the intake. The last 4 bolts (the ones that are on most rear part of the intake) are under the cowl. Anytime you have to remove those bolts the whole intake needs to come off. A major PITA, but that is what is required. You will not have enough clearance to pull them completely out.
02-23-2012, 10:18 AM #3
Can you take the harness off the bracket and just slightly bend it out of the way for it to clear?
02-23-2012, 06:25 PM #4Junior Member
- Sep 2008
Thanks for the information.
I hand to hand saw the top of the bracket off and then shape it with a dremel to get the drivers side rail in place.
I had no choice after i loosened the two intake bolts and they hit the cowl.
BBK was no help and told me they never had a customer who reported this problem.
They also couldnt help me with the fitting I needed to adapt my fuel pressure sending unit to their rails.
Last but not least, I threw away their rubber crossover hose and had a braided SS hose built.
02-24-2012, 03:07 AM #5
Any pics?
02-24-2012, 03:30 PM #6Junior Member
- Sep 2008
Yes, I have a few pics but I dont know how to post them.
I tried uploading them but each time the upload failed.
Any advice?
02-24-2012, 07:03 PM #7
02-26-2012, 05:00 PM #8
Kind of hard to see the rails in the pics, but they look good. How's your clearance between the tensioner pulley and braided line to the solenoid? Looks kind of close...
Ls6 fuel rails
By jking78 in forum Parts For Sale / TradeReplies: 2Last Post: 06-05-2015, 07:41 AM -
fuel rails
By herelizerd in forum External EngineReplies: 1Last Post: 06-02-2014, 03:24 PM -
Question: Fuel Rails
By 35th-ANV-SS in forum External EngineReplies: 8Last Post: 04-21-2011, 07:15 AM -
removing fuel rails
By RealLiveMD in forum Internal EngineReplies: 4Last Post: 04-27-2007, 01:41 PM -
F.A.S.T. Fuel Rails for LSX Mounting DON'T FIT
By LS2Tuner in forum External EngineReplies: 6Last Post: 09-19-2006, 04:24 PM
