Results 1 to 19 of 19
Thread: Progress so far
    Member red00bird's Avatar
    May 2011
    Staten Island, New York, Unite
    2000 trans am
    Progress so far
    Doing a cam swap riming chain intake oil pump and valve springs
    Polluter,410 gears,ls6 intake,pacesetter long tubes ,tsp true duals,slp pulley,slp lid,stock pp throttle body,strano springs n sway bars,founders performance stb,Lca's and Lca relocation brackets,adjustable phb and phb relocation bracket,umi 3point sfc's ,diamond stg2 clutch,koni 4/3s,mgw shifter
    What chain and oil pump are you going with?
    May 2011
    2000 trans am
    I got a ls2 timing chain and a high flow ported oil pump both cam with the polluter cam from tick
    Are the pump and chain a simple swap or do you need to modify the front cover?
    May 2011
    2000 trans am
    Its very simple just pull the timing cover off the. Unbolt the cam gear take the old pump off the pick up tube headers and swap just be careful not to pinch the o ring on the pick up tube
    What is the difference between the LS1 and LS2 timing chain set up? I have heard of others making the same swap, but no one has ever quantified the reason.
    May 2011
    2000 trans am
    Just by looking at them side by side it seems the outer links are a little thicker not by much though
    Member Redrokit8's Avatar
    Aug 2011
    Roseland NJ
    Pewter Silver
    2002 Trans AM WS6
    This is a great post and I look forward to more thumbnails of your progress. Basically this is the exact same type of swap I would like to do. Thanks for posting it and answering Jeff's informative questions. Very beneficial to guys like me who plan this type of modification.
    Magnaflow Quad Tip, Lid, SBellow
    UMI: FTC, FSB, RSB, LCA's, PBAR, SFC's, T-Arm w/relo, D/S Loop
    Kooks LTH, 3" YP, H/F Cats
    Custom Grind Cam, Stall, 3:73 rear
    Bilsteins w/Strano Springs Conti Super Contacts
    TuneByFrost MSD Wires
    Cross Drilled/Slotted Rotors w/Ceramic
    May 2011
    2000 trans am
    This is the first time im doing this swap also ls1howto.com is very very informative I learned alot of there
    Member Guerrillakilla13's Avatar
    Feb 2011
    Arizona
    2002 Trans Am WS6
    You know what the first thing is that you gotta do once the whole things complete right?
    2014 Camaro: Check. 2SS: Check. 1LE: Check. 6 Speed manual? CHECK
    May 2011
    2000 trans am
    Put oil and coolant and tow it to get tuned
    May 2011
    2000 trans am
    Here's some more pics
    May 2011
    2000 trans am
    Rods instead of the jpr tools
    May 2011
    2000 trans am
    Old cam is out new is in
    Member RONS98TA's Avatar
    MARYLAND
    BLACK
    1998 PONTIAC TA
    I used the old metal cloths hanger when i did my cam swap. Lol. price was cheaper for them.
    Any issue with the lifters staying up after you rotated the camshaft prior to inserting the rods?
    Much stronger single roller chain then the stock LS1. Very good setup for setups under>600 HP, after that most go to double rollers
    May 2011
    2000 trans am
    No I didn't have any... turn the cam 6 times put the rods in and pulled the cam out and the lifters stayed up the left rod didn't go in because the opening looks like a d shape so I actually took long zip ties and taped them together and work just as well .. but because it worked for me doesn't mean it will for you I got lucky I guess .. those rods aren't there for the lifters to rest on more like insurance if they fall they will fall on the rods
    MARYLAND
    BLACK
    1998 PONTIAC TA
    Nope. Just gave the cam a few quick spins, then gently pushed in the hangers.
  1. A work in progress!!!!!!
    By GrapeApeTA in forum Firebird / WS6
    Last Post: 08-02-2016, 09:06 AM
  2. A Work in Progress
    By 1990camaroRS in forum Member's Rides
    Last Post: 07-23-2007, 07:12 PM
  3. Exhaust progress of my WS.6
    By Mr. Luos in forum Multimedia Section
    Last Post: 11-18-2006, 07:29 PM
  4. my ws6 progress so far
    By ls1bandit in forum Appearance Section
    Last Post: 11-09-2006, 10:13 AM
  5. progress on Ed's car.
    By Fire Chicken of Doom in forum Western Members
    Last Post: 10-15-2006, 07:46 AM
