Results 1 to 2 of 2
    Dec 2008
    San Antonio, Texas
    1997 ws6 Trans Am
    Angry Camshaft versus Crankshaft dot location to reflect TDC
    I have disassembled and reassembled my timing 3 times.
    I have lined up my dots for the Camshaft at 6 o'clock and my Crankshaft at 12 o'clock. My Dowel pin for my Camchaft is at 3 o'clock. With what I believe is TDC on my first piston.
    I have read a book called How to Rebuild Small-Block Chevy LT-1/LT-4 Engines. Page 149 under "prepare the engine for Distributor" it indicates that both dots are to be at 12 o'clock with the camshaft dowel being at 9 o'clock .
    In the Haynes Repair manual, Chapter 2, Section 10 under installation, step 15 indicates " Loop the new chain over the camshaft sprocket, then turn the sprocket until the timing mark is in the 6 o'clock position. Illustration shows dots at 6 and 12, Cam at 6 and Crank at 12.
    Which is right? I have a 97 TA/ WS6 LT1 5.7L. This is my last attempt to fix otherwise a .45 cal is in call, straight to block. Engine Block that is.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    I prefer a stick of dynamite.
    Cam to crank timing is correct with the Cam @ 6 and Crank @ 12.
    Then rotate crankshaft until engine is at number 1 cylinder top dead center (TDC) (camshaft sprocket pin at the 9 o'clock position) to install the distributor
  1. Question: Camshaft and Crankshaft dots
    By intel76ligent in forum Internal Engine
    Last Post: 02-14-2012, 09:27 AM
  2. Question: 03 durango crankshaft sensor and camshaft
    By JayTA98 in forum General Help
    Last Post: 05-16-2011, 08:41 AM
  3. WEC live tonight aug 18, versus or versus HD
    By ibanez7 in forum Almost Anything Goes
    Last Post: 08-18-2010, 01:40 PM
