    Junior Member laviente's Avatar
    omaha,NE
    Something doesn't seem right
    So I took my gto to get tuned after I put LTs and a cam on it(ls1) and only came out with 360hp to the wheels. Its a tx speed 228r cam and I have a k&n cai. I have 3" pipes coming off the headers straight to a spintech side exhaust. Do I have a shitty set up or is that the numbers I should be getting?
    Thanks in advanced
    Lavi
    with the GTO's the temps that it was dyno'd at will make a big difference. They like to heat soak quite a bit. I personally would probably expect a few more HP there but not a ton on stock heads. Also, what did your car base dyno at? Try not to get too caught up in numbers......what matters is gains at the track. The dyno is just a tool.
    omaha,NE
    I've never taken it to the track. I'm in jax. The closest one is in gainsville. Idk the base dino either. I suck,lol
    Junior Member turismoGTO's Avatar
    Feb 2012
    GA,USA
    Turismo Blue
    2004 Pontiac GTO
    That seems right. Thats almost 60 more horses over factory with a cam that only produces 30-45 over then add in your headers and a tune. I put down 404rwhp with a tsp TV.2 cam,Lts,and open exhaust. It was over 80 in that shop and i live in south GA where there is always high humidity. I would suggest a 160* thermostat,UDP,and better intake.
  1. This guy doesn't get paid enough
    By Knight in forum Almost Anything Goes
    Last Post: 06-10-2010, 02:55 PM
  2. Who has em' Who doesn't?
    By Smkn_TA in forum Almost Anything Goes
    Last Post: 06-09-2010, 05:11 PM
  3. Sig doesn't tell the tale!
    By PFM in forum Request and Feedback
    Last Post: 08-08-2007, 07:19 AM
  4. It doesn't get much better than this...
    By SharkTA in forum Firebird / WS6
    Last Post: 02-19-2006, 01:01 PM
  5. car doesn't start
    By BlackTA00 in forum General Help
    Last Post: 09-16-2005, 08:48 AM
