Results 1 to 11 of 11
    Member Guerrillakilla13's Avatar
    Feb 2011
    Arizona
    2002 Trans Am WS6
    illumination light on door panel
    Does anybody know where i can get one of those small red lights that light up the control panel on your door? My passenger side went out and I have no idea where to look for one.
    Any help is appreciated. Thanks!
    Indianapolis
    2000 WS6 6spd Hooker LT
    If you take off the trim piece on the door release, you can then take off the bulb and match it up at an auto parts store that has a large mini-light selection. The bulb really isn't red, but a normal one with a red cap on it. I've replaced both of mine as well.
    I've also had to replace the small lights for the steering wheel radio controls. These bulbs had to be unsoldered/resoldered to the small circuit board, and I found those lights at Radio Shack.
    Feb 2011
    Arizona
    2002 Trans Am WS6
    Sounds like a good idea! All i have around here is Checker and Autozone, but i haven't seen any light bulb selections from them everytime i walk in. But next time i'll ask and check. Thanks!
    Indianapolis
    So, I fixed my passenger door light issue today. The bulb number was a 37, and it looks like a #74 would fit as well. One of them is a bit brighter than the other, but IDK which one. I put the 37 in, and it's all golden now. Remember that the power window control panel comes off first before the door release panel. Also, the bulb may be stuck in a bit, so you may need to use some force to pull the bulb out of its' socket. After you get the door release panel off, (1 phillips screw), twist the small socket that holds the light about 1/4 turn to remove it to access the bulb. I had to use some needle nose pliers to pull the bulb straight out, and of course it broke. But then I got the rest of it and now it's glowing red again.
    Feb 2011
    Arizona
    2002 Trans Am WS6
    I actually just got back from Checker auto parts, and had them order a set of number 37 bulbs for me Should be in tomorrow. Can't wait to put them in, I wonder how it'll look!
    Thank you for that post actually, perfect timing! I don't think I would have known which bulb to get..or them either without your help.
    Indianapolis
    It'll have that nice, red Pontiac glow again!
    Member 79Firebird_99TA's Avatar
    ATL
    99 Trans Am
    Mine are out too. Do the switch covers on the steering wheel just pop off?
    Member godless-phoenix's Avatar
    culver city, Ca.
    Blackened fire chicken
    2000 Pontiac Trans Am WS6
    Quote Originally Posted by 79Firebird_99TA View Post
    yeah they just pop off with like a flat head screw driver...good to know those steering wheel lights can be replaced as well. i had a 99 firebird and the steering wheel light went out on one side and i had no idea new ones could be soldered on there. thanks for the tip too fast!
    Indianapolis
    Now get cracking LOL.
    You're welcome G-P. Just be careful with the soldering.
    Also, I had a '98 Trans Am, the steering wheel radio controls have indents for the volume button on the right side, and also the left button. AFAIK, that was the only year for that, so when I had myt '98 (AT car, and to get an M6!) I swapped those over. They didn't fit quite right, I had to do some small mod to the steering wheel, but I've never had any problems. I've always wondered why they did that, the '98 style has a much better tactile feel.
    02 Silver T/A-6 spd Waynestep's Avatar
    Feb 2006
    Reinholds, PA
    2002 Firebird T/A - WS6
    My driver side light in the door just went out too--but--- how do I remove the power window control panel first since it overlaps the side panel? I didn't want to force it off by prying if there is another way. It seems to be a loose/snap fit, but I want to know the proper way to remove it... obviously.
    Thanks!
    Feb 2011
    Arizona
    2002 Trans Am WS6
    http://www.ls1.com/forums/f6/how-ins...ow-motor-8307/
    Check out that link provided in the first post. It'll give you some step by step on how to remove the panel (for the window motor install, but the first few steps will work for just removing the door control panel)
  1. Question: 1998 Camaro electric windows and door locks illumination
    By Ted Von Kampen in forum Stereo and Electronics
    Last Post: 02-14-2012, 09:37 AM
  2. door panel
    By edrvsqz1980 in forum Firebird / WS6
    Last Post: 05-17-2010, 03:42 PM
  3. Ash tray light and Door Panel Lights???
    By Patsy57 in forum Stereo and Electronics
    Last Post: 04-24-2008, 02:47 AM
  4. WTB: 00-02 Int. Door Panel
    By Bouvers in forum Parts Wanted / Trade
    Last Post: 03-09-2008, 03:36 PM
  5. Firebird Door Panel Crack Repair - Door Panel Pandemic
    Last Post: 10-18-2007, 10:50 AM
