Results 1 to 20 of 30
    Sep 2010
    Bel Air, Maryland
    '02 Trans Am WS-6, 6M
    '02 T/A WS6 Sail Panel Monsoon Speakers????
    Hey all,
    My T/A has the 10 speaker 500 watt Monsoon system. I'm starting to get a little speaker "vibration" in the right sail panel speaker when playing music on the radio. I'm figuring the speaker is starting to go. Are all the speakers for the Monsoon system 2 Ohms? What do I need to worry about should I need to replace these speakers?
    Member godless-phoenix's Avatar
    culver city, Ca.
    Blackened fire chicken
    2000 Pontiac Trans Am WS6
    speakers definitely blown...ive gotten my replacement ones off of ebay, and they're a "newer" designed speaker that doesnt blow as easy. havent had any problem since, so guess they do what they say...
    culver city, Ca.
    Sep 2010
    Bel Air, Maryland
    I was really looking for an aftermarket speaker. I know what the factory speakers are usually made of, and aren't impressed by them. Is there an aftermarket speaker setup that is designed to work?
    culver city, Ca.
    yeah, im pretty sure any 4 ohm 6" speaker...but youll have to do some wire cutting and all that fun stuff, haha. i think i had kenwood or pioneers on my old Z28.
    blah '02 WS6's Avatar
    white deer, tx
    '02 trans am ws6
    If you're going aftermarket, the Bazookas from Kee Audio are great.
    '02 ws6.....mods? nope
    Member BadTA00's Avatar
    Feb 2006
    Riegelwood
    2000 Trans Am
    The CDT AUDIO HD-6 M DVC 6. 5" DVC Subwoofers from Kee Audio are good also. And they are extremely easy to install. All you have to do is to cut the connectors off the factory speakers, strip the end of the wires and put them in the quick connects and plug the connectors back into the car.
    Sent from Motorola ATRIX 4G on Tapatalk
    2000 T/A-DMH Cutout, SLP Cold Air kit, FTRA/SLP Upgrade, SLP Bilstein, LT1 Eibach ProKit, Kuhmo PA31 Tires ,SLP Fan Switch, UMI Double Adj PHB w/ Roto-Joints, UMI LCARB, Strano 35/22mm Sway Bars , Magnecor KV85 Wires, Hurst Shifter, Lou's Short Stick.
    Sep 2010
    Bel Air, Maryland
    I have no problem with cutting and splicing. I'll probably solder the connector over when I transfer it. So basically I'm just worried about a 4 ohm 6" speaker. No max watts or anything else? It also looked like, in the picture for that auction it was a one way, is that correct???
    Feb 2006
    Riegelwood
    2000 Trans Am
    Just any speaker is not going to work well. You'll want a 6.5" midbass/subwoofer that is Dual Voice Coil in the sail panels. Unless you plan on doing away with hatch speakers and routing their wires to the sail panels.
    Sep 2010
    Bel Air, Maryland
    Quote Originally Posted by BadTA00 View Post
    Even though the thought of removing some speakers to shave a few pounds does appeal to me, I plan on retaining the overall layout. Thats why I am asking for this information. so I need:
    1) 6.5" midbass/subwoofer that is Dual Voice Coil
    2) 4 ohm
    is there anything else I need to worry about???
    Pony_eater Pony_Eater's Avatar
    Aug 2008
    Murrieta, Ca
    2000 trans am ws6
    check out kee audio they have the stuff you need
    Feb 2006
    Riegelwood
    2000 Trans Am
    Look here for some suggested replacements:
    http://www.keeaudio.com/fbodyspeakers.html
    Mar 2012
    MICH
    Black N Gold
    02 WS6 / Ls6 with mods.
    Need to replace mine too . Prob go factory , any tips on removing the panel ?
    culver city, Ca.
    Quote Originally Posted by MeanMachine1 View Post
    dont have to remove it...just pop off the speaker cover and there's 4 bolts holding it to the sail panel. take the bolts off and then unplug the speaker from the connector. installing is just the reverse...after market speakers are a little more involved, but cutting/connecting the wires is a piece of cake
    Feb 2006
    Riegelwood
    2000 Trans Am
    The stuff from Kee is much higher quality than factory junk and much more affordable.
    The covers can be gently pried off. When removing the speaker screws be careful not to loose the nuts.
    Sent from Motorola Atrix using Tapatalk 2.
    culver city, Ca.
    oh yeah! those darn clip on nut thingies...ive lost a couple of those haha. after that i used electrical tape to keep them from moving around or falling down into a black hole haha
    Sep 2010
    Bel Air, Maryland
    I just purchased a set of JBL GT6-6's for the sail panel. I was going to install it over the weekend, but someone smacked the rear bumper on my car (and also cracking the passenger trim board). I spent the time fixing the trim board instead. I still trying to figure out how I am going to solder the harnes to the speaker while inside to car. I wish there was a conecter adapter out there instead.
    Sep 2010
    Bel Air, Maryland
    I am not seeing anything about these JBL's being DVC's and the person on the line at Crutchfield is telling me that theres no aftermarket speaker or subwoofer that would work in the "sail panel/b-pillar" without bypassing the amp or just distorting and destroying the speaker. They are sending me a call tag for return.
    Will these "Bazookas" (CDT AUDIO HD-6 M DVC 6. 5" DVC Subwoofers) from Kee Audio definately retain the functionality and (better) quality as the factories in that spot? I really don't want to mess with things that much.
    Feb 2006
    Riegelwood
    2000 Trans Am
    The Kee Audio speakers (Bazooka or CDT) are DVC just like the factory speakers. Just cut the factory connections off your old speakers and wire them to the new speakers.
    Sep 2010
    Bel Air, Maryland
    I've been having problems getting an email response from Kee on the warranty of the CDT's. Does anyone know what warranty the subs' come with? I would really like to order them, but want to know this info first.
  1. Sail Panel Speakers
    By idle in forum Stereo and Electronics
    Last Post: 08-03-2011, 05:29 PM
  2. WTB: Camaro Monsoon Sail Panel Speakers
    By 99Hugger in forum Western Members
    Last Post: 07-09-2008, 02:34 PM
  3. Replies: 9
    Last Post: 07-14-2007, 04:45 AM
  4. 98-02 Monsoon Sail Panel Speakers!! On Ebay
    By 4U2ENVY in forum Parts For Sale / Trade
    Last Post: 06-17-2007, 07:08 PM
  5. Seat belt guides and sail panel speakers (monsoon).
    By TransAmMan in forum Parts Wanted / Trade
    Last Post: 10-06-2005, 09:19 PM
