Thread: dr question
04-01-2006, 07:31 AM #1
dr question
Looking for some dr's for my car, I have the stock wheels on my car (17 x ?). I have had 315/35/17 Nitto 555 dr's and they are ok. What is the best dr that I can get that has good stick, but will last a long time, it will be driven everyday, and at the strip every once in a while.
04-01-2006, 08:11 AM #2
- Thornton, CO
Nitto.
If you have the stock wheels, you shouldn't be running a 315.
04-03-2006, 03:18 PM #3
Originally Posted by Mr. Luos
04-04-2006, 10:08 PM #4
- Oct 2005
- Chicago burbs
sebring silver- 98 camaro SS
nitto 315's run small they are only a little bigger then a 285 in a non nitto tire my good year 315's are about a inch wider then the nitto 315 on and off rim
04-09-2006, 11:43 AM #5
04-09-2006, 01:07 PM #6
- Nov 2005
- Lost in Texas
Custom Slate Blue- 99 B4C
less width in a tire has nothing to do with sidewall size, a 315/35 is the same height as a 275/40
04-18-2006, 02:21 PM #7
Mickey Thompson's are up there as well as far as stickiness...but forget tread life man, I'd get some wheels w/ your radials and have two sets of back tires, one for racing, one for daily driving. Just my opinion man.
04-18-2006, 09:47 PM #8
Originally Posted by z_driver1
04-23-2006, 05:03 PM #9
what will happen is the tire sidewalls will 'roll' more. this makes for less cornering ability. better straightline launching. the thing to really look for is the tread width vs rim width. once the tread width exceeds the rim width is when it starts to 'roll'. meaning the tread area gets pulled out of shape. i run the 315 on my 9.5" wheels. it's fine. 9" is pushing it though.
speedometer question + top speed question
By Krazy351w in forum General HelpReplies: 7Last Post: 06-21-2007, 05:51 PM -
HPIII question (not the same old question)
By slims00ls1z28 in forum Computer & TuningReplies: 5Last Post: 06-01-2007, 04:55 PM -
97 Bird Headlight question also engine noise question
By Zapper2003 in forum General HelpReplies: 2Last Post: 12-13-2006, 03:03 AM -
Speedometer question, RPO question
By acrylicophobia in forum Firebird / WS6Replies: 12Last Post: 11-02-2006, 07:08 AM -
Sex Question spinoff- PORN QUESTION
By egaian in forum Almost Anything GoesReplies: 77Last Post: 07-26-2006, 03:07 PM
