Results 1 to 11 of 11
Thread: Alternator/Charging question
01-20-2012, 06:30 AM #1Junior Member
- Oct 2007
- nova
White- 2000 WS6
Couple days ago, my alternator goes out (2000 WS6), and I replaced it. During the process, I snapped the exciter cable as I hear is common, so I spliced the cable. Car has been running great.
Today, as I'm pulling into work, I notice the gauge shows shows it's charging at 11v -- which is in the "low" yellow area of the gauge. Turned the car on and off a few times while fiddling with things, and at one point it went back to 13v, but soon thereafter went back to 11 -- like it doesn't NEED to be charging.
Is this normal? I thought it was supposed to maintain at 13.9-14.4 or so? Maybe I didn't fix the exciter plug as well as I thought I did? Thanks!
01-20-2012, 07:30 AM #2Electrical Engineer
- Jul 2009
- North of the Motorcity
I would double check all your connections. Make sure their clean and solid.
Secondly, you probably bought an aftermarket alternator, which are typically crap. If all your connections are good, you might have a bad voltage regulator/bad alternator. Can you take it to a place to get tested?
01-20-2012, 08:41 AM #3
Have your battery load tested, and as Kevin states have the ALT. tested while you're @ it..
01-20-2012, 08:42 AM #4Junior Member
- Oct 2007
- nova
White- 2000 WS6
The battery is 3 months old. The alternator is brand new. For purposes of this discussion, I am going to assume they work fine. Is this something that a bad connection in the exciter cable could cause, where it's charging normally then charging low?
01-20-2012, 08:52 AM #5
01-20-2012, 08:53 AM #6Junior Member
- Oct 2007
- nova
White- 2000 WS6
It's a NEW, new alternator.
01-20-2012, 09:01 AM #7
You do understand that alt's for these cars have been out of production for years right?
The odds of it not being a remanned unit are very slim at best..
Where was the alt purchased from?
01-20-2012, 09:59 AM #8Junior Member
- May 2009
- Santa Maria, California
Black- 1998 Pontiac Formula LS6
Correction on one of your descriptions; DIS-charging at 11V. Voltage is leaving the system. Not going in to it... Better put a meter on your battery to check the actual charge.
01-20-2012, 10:52 AM #9Junior Member
- Oct 2007
- nova
White- 2000 WS6
The battery appears to be 11v too when the car is running.
01-20-2012, 12:18 PM #10Junior Member
- Oct 2007
- nova
White- 2000 WS6
Just figured out the PS pump is leaking. Seems to be a common cause of alternators going out. Maybe that's what did in the old one but I doubt it could cause the new one to stop working in only 24 hours, could it? Nevertheless, it seems I will be ripping into that one tomorrow.
01-20-2012, 01:52 PM #11Spaz is My Mentor
Sorry op, I just dropped in this for the first time. Yes the PS pump is the number 1 cause of alternator issues. It depends on how much fluid was dropping from the pump but yes it can kill an alternator in 24 hrs. ASK ME HOW I KNOW
If you look in the stickies there is a thread that may be able to help you dealing with this issue.
Most likely cause is the o rings on the high pressure hose going out. cost under a buck, but that's not including the replacing of the alternator.
If you are going to work on the PS pump remove the alternator first do the PS pump job then clean up and then install the alternator.
Any questions drop me a line. I wrote the sticky on this issue.Last edited by SMWS6TA; 01-20-2012 at 01:54 PM.
Help: 2000 lS1 (Charging system issue/question)
By TerribleTed in forum General HelpReplies: 17Last Post: 01-16-2011, 08:27 AM -
Alternator charging wire!!!!
By jb3golf in forum General HelpReplies: 4Last Post: 05-22-2010, 10:22 PM -
Amp and alternator question
By Archaelas in forum Stereo and ElectronicsReplies: 5Last Post: 12-10-2009, 12:18 PM -
alternator not charging battery...HELP
By Unfrozn in forum External EngineReplies: 4Last Post: 11-05-2007, 06:32 PM -
Alternator question
By milleniumz in forum General HelpReplies: 6Last Post: 01-09-2007, 11:53 AM
