Results 1 to 16 of 16
    Jan 2012
    PA
    Help selecting a car
    I'm looking to buy a 98-02 T/A. I noticed that you could get a basic T/A or you could get it with the Ram Air/WS6 package.
    What does the Ram Air/WS6 package give me that is not in the base T/A (they both have the 5.7 LS1)? Is it really worth it?
    One of the cars I'm looking at I think has a fake Ram Air set up (or maybe aftermarket). It has the Ram Air stickers on the hood, but doesn't have the WS6 on the rear end. Are these after market Ram Airs as good as the factory Ram Air setups?
    Thanks for the help
    Carl
    Member derekbuckner1's Avatar
    Oct 2009
    West Virginia
    LPM
    2000 Z28
    To my knowledge the ws6 package is a hood, power steering cooler, and thicker front sway bar. Take that for what it's worth. The ws6's also tend hold value better than a trans am.
    Feel free to correct me
    LS6 Intake, LS6 VCT, E^2 Catch Can, Hooker LTs and ORY, Magnaflow Cat-Back, 3" QTP electric cutout, UMI adj LCA, PHB, 3 pt SFCs, STB, MGW Shifter, SLP lid and bellow, Free-Mods, Tuned by BlueCat
    Junior Member smokestack's Avatar
    May 2011
    Terre haute IN
    blue
    2001 silverado
    Good thread. I was just after this info. Found 2 nice TA,s and the WS6 is like 5 grand more....
    Oct 2009
    West Virginia
    LPM
    2000 Z28
    As for the aftermarket hoods, the stock ws6 hood has baffles inside of it that greatly reduce any "ram air" that flows through it.
    Any functional ram air hood, or one with the baffles removed will provide more air to the air box
    Marylandistan
    2001 Trans Am (sold)
    The hood is merely a cosmetic option. If you like it, great, but it doesn't make your car any faster. Also comes with 17" wheels.
    Oct 2009
    West Virginia
    LPM
    2000 Z28
    Quote Originally Posted by INMY01TA View Post
    Wasn't sure about that but had a feeling I missed something.
    +1 on minimal gains if any from the hood
    Auto Painter RyanJM's Avatar
    Houston, TX
    Depends on what you plan to do to the car. Mine is a normal TA with aftermarket WS6 hood debaffeled. I have changed all the suspension, ehaust, wheels, and intake so if it was a WS6 all that would be left would be the hood. WS6's are nice if you don't plan on doing alot of mods they do have the larger wheels, some suspenion upgrades, and a better catback as well I beleive. Depends on your plans and the price difference between them. $1000 or so get the WS6 since those hoods are expensive but I wouldn't pay $5000 more.
    1998 Trans Am 85k miles.
    02 Trailblazer -Sold
    09 Ram 1500 CC - Sold
    09 Cobalt SS/TC - Sold
    Senior Member Lunatikgixxer's Avatar
    Mar 2010
    St Pete, FL
    Bat mobile black
    2000 Trans am WS6 M6
    like ryan said. It depends what you want from the car. If you plan on modding the piss out of it and changing stuff like the Heads and Cam, rear end, etc etc. Then id go with the base model TA. If youre trying to find a car that is pretty much stock to just drive around and get on here and there then get the WS6 because itll be easier to sell in the future for more money because it holds its value a lot better. Virtually theres not much of a difference between the two, just small features here and there.
    Member bouigha123's Avatar
    Mar 2011
    MD
    1999 Formula ws6
    The ws6 option got you the ram air hood with raised air box, which uped the hp to 320. You also got a thicker front sway bar and 17 inch wheels that came standard with 275 rubber. Also you got a power steering cooler to help with the biggar rubber. A ws6 will hold its value better than a regular ta or formula but if your not worried about that you can spend that money on mods and be quicker than a ws6 for less than one.
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    IMO, looks and "collectability"/"rarity" are what you get out of a WS6.
    Performance is close enough to be neglected, IF you plan on modding. If your going to leave the car stock, I would go with WS6. If ypur going to mod it, you'll end up changing the things the seperate the two anyways.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    You can also look at the RPO code inside the driver's side door to tell whether or not the car is a real Ws6.
    He had another thread asking similar questions that I hooked him up with the sticky threads on F-bodies & RPO codes.
    Import Ambassador nomolos1's Avatar
    Jul 2010
    Georgia
    black, black Twins
    93 Supra , 94 Supra Turbo
    Mine had the Rapter hood. I replaced the airbox with an open K&N cone intake. Then I cut holes behind the grills in the hood. I could feel the difference. I was very mindful about driving in the rain after that. Didn't want vapor lock.
    It's gotta be fast and sexy.
    93 Supra T 6spd,(1 of 197) 1K WHP build under way. Streetable!!!!!
    94 Supra Turbo(1 of 549) 600 rwhp on pump gas. 700+ rwhp on race fuel.
    http://i902.photobucket.com/albums/a...foronemore.jpg
    ^^ "Hydrolock" is what can occur when water is sucked into the engine.
    And vapor lock happens when the motor is so hot that the fuel vaporizes while in the intake. Doesn't happen as much with modern cars as it would the old ones (carb, cast intakes, etc from the 70's on.
    Member Ant71130's Avatar
    Aug 2010
    Lebanon, OH
    2002 M6 WS6
    Not like you haven't gotten your answers but plain and simple, here you go. To the best of my knowledge...
    WS6: Came with the WS6 hood, which yes is baffled and normally is $6-700 to buy a real one, so the hood is worth paying a little more for. The raised airbox also was included.
    Came with 17" wheels, with 275/40/17's all the way around. The base TA had I believe 245/50/16's or something to that nature.
    The muffler was slightly free'er flowing, but the piping was the same, 2 3/4".
    Came with a 32mm front Sway bar, as opposed to... no idea lol.
    Power Steering cooler.
    Shocks/struts...not sure if the decarbons were on the base model as well? Someone can clarify.
    Basically, even with "everyone does these" mods, you ditch the need for a WS6. Lid, there's your airbox. Exhaust, there's your muffler. Rims, there's your personal tire size. Suspension you can do as you please, it's more about the rarity as someone else said. Not saying they're rare but, f you're going to have a car that isn't made anymore, people like buying te "best" trim they came in. It's all your preference, you won't really have a faster car either way, though the WS6 is cooler . Plus you don't have to spend time getting an aftermarket hood.
  1. When selecting a wife.......
    Last Post: 11-01-2009, 01:07 PM
  2. Need Help with selecting a cam
    By ledesma54 in forum Internal Engine
    Last Post: 09-08-2009, 05:46 PM
  3. Need help selecting a Turbo setup?
    By tyls6ta in forum Forced Induction
    Last Post: 10-15-2007, 04:09 PM
  4. Selecting a braking system
    By 2000 SS #1305 in forum General Help
    Last Post: 08-31-2006, 04:17 PM
  5. need help selecting a shifter
    By lmt0705 in forum Manual Transmission
    Last Post: 02-14-2006, 04:19 AM
