    Aug 2010
    albuquerque nm
    2000 chevy camaro
    1998 camaro with a 2000 camaro engine
    I bought a 1998 camaro and I had a 2000 camaro engine with the complete engine harness and put it into my 1998 camaro but I can not get none of my guages to work. I have three plugs on the passenger side and only two connection from the engine. Im lost can anyone help me out. You can email me at [email protected] thanks Timothy
    Senior Member redbird555's Avatar
    Mar 2009
    pompano beach florida
    2002 Camaro Z/28 Pewter
    what engine is it? ls1 or v6? if I'm understanding correctly you had a 98 camaro, now did you have a 98 pcm in it or did you use the 2000 pcm? All of these things matter you cant just put a 2000 pcm in a 98 car because the gauges look for an analog signal and the 2000 pcm will send a digital signal causing it to not function also a 98 engine harness has different pinouts for the pcm so it cannot be used. In short it sounds like you need to get a 98 harness and a 98 pcm and then go from there.
    Aug 2010
    albuquerque nm
    2000 chevy camaro
    1998 camaro help
    Its is an ls1 engine that was in a 2000 camaro with the 2000 engine harness and im trying to put this engine in my 1998 camaro z28
    Drop&Drag matt evans's Avatar
    clyde nc
    02 Z28 and 00 SS
    if your going from a ls car to a ls car i dont see why you should be changing the harness. Only thing i can think that is different is the coil pack brackets and the valve covers.
    Mar 2009
    Quote Originally Posted by ortiztimothy View Post
    Then it goes back to what I said originally. You CANNOT use a 2000 harness and or pcm in a 98 car in order to get that engine to work you will need a 98 pcm and harness or completely change the car over to a 99-up pcm system. IMO its easier to just get a 98 pcm and harness
    Quote Originally Posted by matt evans View Post
    he must change the harness because the 98 pcm uses completely different pinouts for the pcm and harness as well as having 3 plugs under the dash instead of 2. So while it may look like the same thing none of the gauges will function. he must either convert the car over to a 99-up pcm system or just get a 98 harness and pcm if the car still doesnt have one
    Member jetaws6's Avatar
    Apr 2009
    Fallston, Maryland
    1998 Trans Am Ws6
    I hate to bump such an old thread but if I am reading this correctly upgrading from a 98 harness to a 99+ will eliminate the 3rd under dash connector? I had to swap to a newer pcm and harness in my car for tuning the new setup and I have this extra connector when I am not sure if it is needed or not.
    The '98s have some differences from the later model 4th gens. Sounds like this is one of them.
    Apr 2009
    Fallston, Maryland
    1998 Trans Am Ws6
    Yeah it sucks how different they are. I put a 370 and F1-A in my car and changed to the newer ecu and wiring harness. There were a couple connectors that were different but this one just has no where to plug into. I am hoping it just isnt needed anymore.
    Best thing to do is get the wiring schematics -- you can usually pick up a used set of factory service manuals for around $100 from a book dealer at a swap meet or on-line... maybe e-bay.
  1. Replies: 3
    Last Post: 05-19-2014, 05:46 AM
  2. For Sale: 1998 Camaro Z28 *New LS1 Crate Engine*Full Bolt-On's*Tuned*
    By Castle in forum Vehicles For Sale / Trade
    Last Post: 02-06-2011, 12:51 PM
  3. Used LS1 Engine Block Camaro Z28 1998
    By zaragusa in forum Parts Wanted / Trade
    Last Post: 10-14-2008, 04:13 PM
  4. Wanted 1998-2000 Camaro Automatic
    By NHRAF156 in forum Vehicles For Sale / Trade
    Last Post: 12-28-2006, 08:28 PM
  5. 1998 Z28 vs. 2000 SS camaro
    By stevo5662 in forum Kill Stories
    Last Post: 05-13-2006, 10:44 PM
