Results 1 to 18 of 18
    Aug 2010
    NEW ALBANY
    2002 ws6 ta convertible
    supercharged 3.8 swaps
    can you take the super charger off a fwd 3.8 and put it on lets say a camaro 3.8 and make it work. just wanted to if it was possible or not thought about trying somethig stupid with a s10.
    Member flybird's Avatar
    Jun 2010
    Houston
    Mid Night Blue
    1999 Firebird 3.8 series
    you'd think so bc there the same engine.. I am not sure, but Smittro will step in soon and tell you.
    LaGrange, Indiana
    2001 Camaro SS hard top
    I don't think they work in f-bodys because the intake of the sc would be pointing at the fire wall, but i'm not 100% sure. could work in an s 10 if there is room to run an intake w/90 elbow maybe
    Pittsburgh
    2008 Hummer H3
    Sorry I missed this guys..
    But yes, it's doable..
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by Shermanator86 View Post
    You can make it work in both the S10, and the 4th gen f-body.
    Just have to make a U-turn..
    Of course there's a little more to it than that but definetly can be done.
    Pittsburgh
    2008 Hummer H3
    There's also always the procharger type system route too, and of course turbo charging also.
    Aug 2010
    NEW ALBANY
    Nice that would be a great sleeper truck.
    Sent from my DROIDX using Tapatalk
    TRUE DUALS
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by REVNORR82 View Post
    Agree!
    Only issue will be,,, traction!
    Seeing how you already have a WS6 TA you're prolly already used to going sideways..
    Aug 2010
    NEW ALBANY
    Sideways is always fun traction problem can be solved.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Makes it easy to do the waterpump but those plugs must be a bitch.
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by 2002ssslp View Post
    I bet they are, the L36 plugs are hard enough let alone that setup.
    They prolly could have been thought threw better but it looks like they were working with a shoe string budget,
    judgeing from the CPVC schedule 40 pipe and the kinked manifold coolant hose..
    Aug 2010
    NEW ALBANY
    I seen that almost wondering if would be easier to put a ls1 in.
    Pittsburgh
    2008 Hummer H3
    I planned on doing that to my exsisting 01 y87 L36 before I got rid of it.
    Before that happened I desided on a DOHC v8 in the Northstar brands..
    Then I got rid of before I even got started since I wanted an H3 Hummer and already have a 3 year old unfinished TT project..lol
    Pittsburgh
    2008 Hummer H3
    Without a better pulley the eton90 is only ~40-45hp gain over the L36.
    Hardly worth the work of changing over to an FWD L67 when they could have just used the L36 and bolted on a procharger or bottled it, and been in LS1 or better territory instead.
    I've heard people say the L67 block and rods are stronger yet provide no proof.
    I think they just want to believe that.
    I've been inside both the L36, and L67 series-II,, both have the same castings,, there is no differences.
    Only the 3800 Series-I had differences in the blocks between the SC and N/A engines and a couple different heads.
    Later when the Series-II arived, it was more cost effective for GM to use the same castings for both L36 and L67 since the overal design was improved.
    Lower compression pistons, slightly heavier valve springs, greater lb/hr injectors, and injector bungs in the heads are the only REAL differences between the two..
    Injector bungs can be drilled into the L36 heads to change them over if wanted.
    This is because the L36 head castings have L67 bung provisions that were just left undrilled.
    GM could have used the L36 higher compression pistons and gave the eton a better pulley but they needed to sell LS1's..
    Aug 2012
    Vancouver
    Hi smittro I am looking for a list of parts I will need to get to do the russel swap on my 3.4 with the grand am heads
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by Tealcamaro View Post
    Russel listed all the parts needed to do the swap in his thread.
    There's also the 3.4/3500 hybrid swaps too.
    ..and Grand Am heads??
    The only ProCharged 3800 Bird I know of is a 1 one off. Supposedly somebody was going to produce her kit but don't think it went anywhere
    Pittsburgh
    2008 Hummer H3
    I think Ed ran a procharger or some other side mount SC on his 3800..
    Can't remember. It's in the post your 3800 thread.
    But ya, I have yet to see anyone make a "kit" for it.
  1. No C2 corvette LS1 swaps here?
    By yzguyfl in forum LSx Retrofit and Swap
    Last Post: 05-01-2015, 08:46 AM
  2. Gen I/Gen II Small-Block Intake Swaps
    By Ed Blown Vert in forum General Help
    Last Post: 07-31-2014, 02:30 AM
  3. Question: Anyone have info on Vette IRS Swaps?
    By thomasterrible in forum Firebird / WS6
    Last Post: 10-15-2010, 07:46 PM
  4. ls1 swaps cool/not let me hear ya
    By crashandburn_01 in forum General Help
    Last Post: 10-24-2008, 11:51 AM
  5. Engine swaps?
    By Firebird Phoenix in forum Firebird / WS6
    Last Post: 02-15-2008, 11:50 AM
