Results 1 to 10 of 10
12-18-2011, 06:31 AM #1
- Sep 2008
- Atlanta, GA,Ft.Walton Bch,FL
- Blog Entries
- 1
silver- 99 ws6
antena going up when playing CD usalley only gos up w/ tuner
I have a 99WS6 and a mid priced Kenwood head unit the only time the electric antena should go up is when the HU is switched to tuner then go down when I change sources.
antena going up when I turn on the unit reguardless of which source was left on during turnoff and when playing CD or flash drive usalley only go's up w/ tuner on then when I switch the source to standby the antena goe's down, switch to either CD or flash drive back up it just started doing this yesterday.
I have had this HU for about 6-7 years no problems.
edit:in recent weeks I have observed the removable display being all pixelated when first inserting then it starts displaying correctly.
edit: the sound quaility has not downgraded still plays fine however I would prefer the antena to stay down when not using tuner. hopefully I won't have to pull the power to the antena and never use it in up position.
Thanks for any helpfull adviceLast edited by qwik219d9; 12-18-2011 at 06:34 AM.
12-19-2011, 04:01 AM #2
- Sep 2008
- Blog Entries
- 1
silver- 99 ws6
anyone
12-19-2011, 04:37 AM #3
If its possible your battery lost a charge it would reset your settings in the head unit. All mine have always had an option to power up for radio or to always have it up with power on.
LS6 Intake, LS6 VCT, E^2 Catch Can, Hooker LTs and ORY, Magnaflow Cat-Back, 3" QTP electric cutout, UMI adj LCA, PHB, 3 pt SFCs, STB, MGW Shifter, SLP lid and bellow, Free-Mods, Tuned by BlueCat
12-19-2011, 07:25 AM #4
- Sep 2008
- Blog Entries
- 1
silver- 99 ws6
if you'r referring to the cars battery over the years I have dissconnected it many times and never had this antena up situation,
this radio doe's have many settings I recently adjusted the time maybe I accidently pressed a wronge setting to create this situation, thanks for the tip however I'm not optimistic about these setting I have adjusted time many times w/ out messing up the antena.
BTW nice looking camaro, ? is you'r E^2 Catch Can a double chambered type and how often do you have to drain it?
Thanks
12-19-2011, 04:07 PM #5
12-19-2011, 06:42 PM #6
Some aftermarket HU's come with a reset button that will restore the factory settings. Look for a small hole on the faceplate that the tip of a ballpoint pen would fit in. If you have one, push and hold it for a few seconds and that should do the trick. Of course, you'll need to re-enter all your stations, set the clock and such.
12-19-2011, 08:21 PM #7
12-21-2011, 03:37 AM #8
- Sep 2008
- Blog Entries
- 1
silver- 99 ws6
12-21-2011, 03:39 AM #9
Glad you got it figured out.
12-21-2011, 05:56 AM #10
Antena Removal Question
By Badass WS6 in forum General HelpReplies: 3Last Post: 12-07-2013, 06:10 AM -
Antena motor
By steffs ws6 in forum General HelpReplies: 4Last Post: 05-27-2006, 08:25 PM -
need help fixing an antena motor
By steffs ws6 in forum Almost Anything GoesReplies: 0Last Post: 05-23-2006, 09:21 PM -
xm radio antena.........
By redz284u in forum Stereo and ElectronicsReplies: 19Last Post: 01-27-2006, 07:14 AM -
alarm antena?
By quicky06 in forum Stereo and ElectronicsReplies: 7Last Post: 11-04-2005, 08:33 PM
