Results 1 to 10 of 10
    Rear defroster repair -- thoughts?
    I had to DD our Suburban last week and noticed an unusual noise from the back of the vehicle. Turns out that the passenger side connector for the defroster grid decided to free itself from the glass. Do I dare apply fresh solder to the connector and then press it to the glass with my solder gun? It would really suck if I ended up cracking the back glass in this thing. I could pre-heat the area a bit with my heat gun to lessen the thermal shock... but just not sure on this one. Thoughts?
    do you have a good gun that would heat the solder up quickly or an iron you'd have to lay on there? I would want something that's good and hot so you can just touch it long enough to melt the solder and be done. They also sell electrically conductive epoxy's you could use if the whole solder thing worries you too much. Just epoxy it back on.
    Member WS6SP33D's Avatar
    Nov 2011
    QuarterMile, KY
    Red w/ silver Stripes
    2000 WS6 6 Speed
    I have te soldered a few back on. I'm not saying you should or should not. I kept the vehicles in a heated garage until the glass was alittle warm then with my quick heart mac solder gun applied solder. I have also heard of people getting someone to hold a heat gun directly behind the element to try and heat the glass while the solder is applied. Good luck jeff
    I have a solder gun that does heat quickly. It would be nice to do this on a hot sunny day when the glass is blistering... but those days are months away.
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    I have multi-temp gun that I would use. Lowest setting with a thin guage solder and you should be fine.
    Could take a blow drier to the glass, lol.
    "Some people live for the rules..... I live for exceptions" N. Hexum
    Well... it's fixed. I started by applying flux and a layer of new solder to the broken off connector. While that cooled, I warmed up the glass with my heat gun. I made sure to heat the glass around the area of the attachment point and not just a single spot. When it was hot enough that I couldn't leave my hand on it, I held the connector in place with a small screw driver and pressed the solder gun to it until it smoked and the solder flowed out. After removing the heat, I held it in place for a few more seconds and then allowed it to cool for a while before testing the strength of the bond and re-attaching the wire harness.
    Thanks for the replies!
    Nov 2011
    QuarterMile, KY
    2000 WS6 6 Speed
    Nicely done Jeff
    Thanks! Easy to do, but very stressful not knowing what the outcome was going to be.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Glad I read this. I have worked on vehicles with broken heat element connectors and I always wondered how those could be repaired. I know now. lol
    Orlando, FL
    Mean Black
    i did solder mine in the TA and it had hold so far. nice work jeff
  1. rear window defroster
    By milleniumz in forum General Help
    Last Post: 01-15-2015, 02:49 PM
  2. Question: rear window defroster
    By JayTA98 in forum General Help
    Last Post: 05-19-2011, 03:30 PM
  3. rear defroster
    By 04goatinmass in forum Firebird / WS6
    Last Post: 11-23-2010, 06:08 PM
  4. Rear Defroster
    By jrocs00z28 in forum General Help
    Last Post: 10-04-2006, 01:45 PM
  5. Help fixing rear defroster
    By Thewilldog in forum Stereo and Electronics
    Last Post: 11-14-2005, 01:17 PM
