Thread: Wilwood brake kit fitment
12-12-2011, 04:50 PM #1
I found a Wilwood Superlite 6 kit cheap, only problem is it is for a 93-97 camaro and mine is a 2000. has anyone adapted an older kit to an ls1 car? It seems that i would just need a different bracket to mount the caliper. hoping there is an easy fix for this, got the kit really cheap.
12-12-2011, 05:56 PM #2
I took a look at their site and they seem to have some good info.
1997 - http://wilwood.com/BrakeKits/BrakeKi...sc Brake Rear.
2000 - Wilwood High Performance Disc Brakes - Rear Brake Kits: 2000 Chevrolet Camaro
You'll have to do some reading, but my recollection is that there is a difference.
12-13-2011, 04:21 AM #3
this is a front kit but thank you for the links. I think I need to find a bracket that will mount to my ls1 spindle and still have the mounting holes in the right spot for the lt1 kit. Another thing that I could do is get a set of spindles from an lt1 car and just mount the kit as designed. the problem with that is that they require heavy modification and i would rather do it with a bracket.
12-13-2011, 12:40 PM #4
Whoops. My bad. For some reason I thought I read "rear" in there somewhere.
12-13-2011, 01:02 PM #5
it's ok. turns out that a spindle for a 93-97 car will bolt on to a 98-02 car so I'm going to pick up a pair and just swap them so i can mount this kit on my ride. If there is anyone out there who has a 93-97 car and is looking for a complete setup off a ls1 car with 27k on it to upgrade to the 12" ls1 brakes let me know.
will wilwood brake kits fit moser rear end?
By jonnyman in forum Suspension and HandlingReplies: 8Last Post: 07-02-2013, 03:13 AM -
Wilwood 4 piston brake calipers
By tatertot91 in forum Parts For Sale / TradeReplies: 2Last Post: 03-11-2012, 09:18 PM -
Wilwood C5 Big Brake Kit - Brake Check!
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 04-18-2011, 03:20 PM
