    Member Thewilldog's Avatar
    Jacksonville, FL
    2001 Z28
    Is there a backlight behind HVAC controls in a 2001 Z28?
    I can't remember if the HVAC controls were ever backlit or not. If they are supposed to be lit, mine out. Is the bulb easy to get to?
    Member 666ws6's Avatar
    Greenville, SC
    2000 Trans Am Ws6 #2946
    They are back lit on my 2000 TA. yes.
    Orlando, FL
    Mean Black
    you have to remove the trim piece around the radio/ac controls. Then remove the bolts holding the ac controls. I can't remember if the light bulb is integrated in the panel or if they are removable.
    Jacksonville, FL
    2001 Z28
    Replaced the bulbs today. There were two little ones that plug into the HVAC console, guess both had burned out. Here's a little step by step I did replace them:
    As mentioned, to get to the back of the HVAC console, the face panel trim needs to be pulled off and set aside.
    The console is fastened to the dash with the the same type of 7mm hex screws that holds the radio in place. The two bulbs twist into to the top-middle of the console. A quarter turn clockwise (from user's perspective, it's counter-clockwise from the direction the bulb faces) is enough to pull the bulb housing out.
    The replacements are about $5.50 at the auto parts store. I can't figure out how to remove the burned out bulbs without breaking them. There's no way to get a grip with your fingers, and pliers eventually lead to breakage. I ended up breaking both with a pair of needle nose pliers and pulled the bottom of the bulb out by the wires. New bulbs snap into place with a little bit of force.
    Now I'll be able to select my heat/air setting by sight rather than memory.
    Jamestown, NC
    99 Z28
    haha. I need to be fixing those, along with with my auto shift light and the lights in my doors lol. But actually Im just going to delete the ones on the doors.
    Orlando, FL
    Mean Black
    Nice job!
    Jacksonville, FL
    2001 Z28
    Quote Originally Posted by scott5 View Post
    Careful doing the one beneath the shifter indicator. About a year ago I broke the door to my ash tray taking that piece off.
    http://www.ls1.com/forums/f6/there-l...dicator-141907
    Pittsburgh
    2008 Hummer H3
    Nice! Just an FYI for anyone else too, those are the same bulbs as the center console uses as well for you auto guys..
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by Thewilldog View Post
    Question: Is there a lamp for gear indicator?
    LOL beat meh to it!..
  1. Gauge backlight replacing 2001 Camaro
    By Johny Bee O in forum Stereo and Electronics
    Last Post: 11-25-2008, 08:05 AM
  2. Switching the radio with the HVAC Controls
    By ls1camino in forum Stereo and Electronics
    Last Post: 10-15-2008, 11:49 AM
  3. 98 camaro guage cluster and HVAC controls
    By DADillac in forum Parts For Sale / Trade
    Last Post: 06-04-2008, 07:39 PM
  4. F/S firebird camaro HVAC controls
    By powers84 in forum Parts For Sale / Trade
    Last Post: 10-12-2007, 01:00 PM
