Results 1 to 16 of 16
    Dec 2010
    New Jersey
    1998 WS6
    ebay turbo kit hellooooo. why you so cheap?
    98-02 CAMARO FIREBIRD TRANS AM LS1 FULL RACE TURBO KIT | eBay
    soooootempted like what can go wrong other than breaking my rear into tiny pieces
    Coral Springs, Fl
    Sunset Orange Metalic
    You get what you pay for. cracked manifolds, bearing failure, poor quality materials, to name a few common problems. there's a reason you dont hear of many people running those kits
    Sep 2011
    Orlando
    Trans am
    i would get it but replace the turbo, BOV, & wastegate
    Junior Member pewter99's Avatar
    Dec 2011
    north jersey
    pewter
    1999 corvette hardtop
    and alot of cutting in the engine bay
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Don't waste your money. Go with a quality kit and turbo so you do not have major trouble down the road. " You get what you pay for "
    Anyone out there who has tried this kit please let the members know how it worked out.
    Dec 2011
    longwood
    this is what i bought not even a year ago... the jdm stuff is crap..
    bov didnt work so blew ic pipes off
    the wastegate leaked internally soo badly it never boosted enough to open...
    the turbo is soo small you cant rev past 4k... guages and fuel pump are trash... oil lines are trash... hot side and colt side piping are decent... best if you go with a custom downpipe
    Dec 2011
    longwood
    and in addition you need to relocate the alt to top... redo custom or bend p.s. lines including an external cooler...
    wrap hot side and a turbo blanket is a must... and to top it all off the original valve springs valve float under boost
    Pittsburgh
    2008 Hummer H3
    Okay I've heard just about enough here.
    Does anyone here own the kit?
    Does anyone here have experiance with the kits?
    First off many people run them without trouble.
    Second the bad mouthers generally talk about a friends, friends, uncles cousin had a bad one.
    The kits come with explicit instructions for a professional install, so it's no surprise DIY'ers are popping these in their driveways.
    With any machine proper installation and a break in period is required.
    I have the full T4/T3 TT kit and have had the turbos torn down and inspected.
    There were no indications the wet bearing setup or any of the other internals were defective.
    Yep they're cheap, and yep so are many of the factory turbo's used on stock vehicles going over 100k..
    If they pop you can simply toss the effer out and replace it.
    Now I can't speak to the manifolds as there's no company on earth that makes turbo manifolds for my engine so anybody's guess there..
    But could we please keep this to people whom have dirrect experiance with forced induction and JDM/Mirage power turbines?
    I can take a $15000.00 turbo an explode it in my driveway just like a cheap one..
    99.999% of the time problems are going to go to the installer, installation, and or the tune.
    That goes for ANY FI setup, I don't care whether it's a $1000.00 kit or one that costs much much more.
    Anyone without FI experiance that thinks they're going to take a $10,000 Garrett and install it in their driveway and not have problems is crazy.
    Most of the problems you'll see with the JDM are going to be: oil delivery, cool down times, over boosting, and on top of them all general POOR INSTALLATION.
    Dec 2011
    longwood
    Again... The turbo from this spefific kit is too small with only a 50 trim... Would not let the engine spin past 4500... And there was oil leaking into my intercooler... Went with another ebay turbo t67 that i got used and is now spining to 6k with no issues
    And also no instructions were included at all... Only paper i got was an item list...
    And reason for custom downpipe is because fighting these pipes all routing on the side of the steering shaft is a huge pita... And then it still hits the shaft on turns. And also the pipes i had had the pipes that go into 2 then back to 1 to goto cat had to be welded cause clamps wouldnt line up.. and gave me under an inch of ground clearance
    Pittsburgh
    2008 Hummer H3
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by stockenstien View Post
    Sounds good. My apollogies if you took that as dirrected towards you.
    But as far as instructions go that's why they state having a pro install the kits.
    That's why it's important to get with a professional before any work starts.
    This can help avoid later issues.
    Dec 2011
    longwood
    Id say the best way to go is get the godspeed hotside and universal 3in ebay coldside... Ebay turbo.. good name brand wastegate and bov.. custom lines
    Regardless after a lot of work it sure is fun as hell
    Pittsburgh
    2008 Hummer H3
    As a side note I went with a triple boost controller setup, one onboard MAP, and a secondary on board custom controller, with a remote stand alone eletronic controller, since my project is experimental.
    Also using the Mega Squirt-II stand alone with remote touch screen engine monitor, covering everything from AFR's, to boost pressure, with in car USB ECM access ports.
    Dec 2011
    longwood
    Megasquirt is awesome with what it can do... Fun to put together too... But for any oe genIII setup it would be kinda silly considering all you need is a 2 or 3 bar map that plugs right in and a custom o.s. for the pcm
    Pittsburgh
    2008 Hummer H3
    I agree.
    I'll be running in MAF'less speed density with the mega squirt-II since the LQ1 has nearly no after market, and my engine is a virgin GEN-I without cam sensors.
    My build is the first of it's kind using TT's thus far.
    The Mega Squirt-III has been released also with even more capabilities, which has also crossed my mind for the second LQ1 I'm also building.
    I'm still up in the air on whether to FI that build too or not..
    Feb 2008
    Iowa City, Iowa
    Yellow
    2006 Z06 LSX 427 TT Corve
    That is cheap, so what are you going to do?
  1. Cheap brakes or Ebay BS???
    By Z28dryva in forum General Help
    Last Post: 09-16-2012, 05:01 PM
  2. Cheap Ebay Hood
    By GULLETT17 in forum Appearance Section
    Last Post: 01-02-2008, 01:50 PM
  3. Cheap WS-6 on eBay
    By fuzzyhall in forum Vehicles For Sale / Trade
    Last Post: 10-13-2007, 07:47 AM
  4. Cheap WS-6 on EBAY
    Last Post: 10-11-2007, 12:39 PM
