Results 1 to 10 of 10
    Drop&Drag matt evans's Avatar
    clyde nc
    02 Z28 and 00 SS
    Hurst pro billet vs. Pro 5.0 shifter???
    just curious to what some peoples opionions are over the two. What are you running in your M6?
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    I have a Hurst Billet Pro in mine. I like it. Nice, short shifts.
    clyde nc
    02 Z28 and 00 SS
    I drove my buddies SS and he had the Hurst in his car. I liked the throw and the feel of the shifts of it and so i ordered one for mine. Total improvement over stock.
    North Jersey
    2004 GTO M6
    Member BadTA00's Avatar
    Feb 2006
    Riegelwood
    2000 Trans Am
    Hurst Billet Plus, with angled Lou's Short Stick, here.
    Sent from Motorola ATRIX 4G on Tapatalk
    2000 T/A-DMH Cutout, SLP Cold Air kit, FTRA/SLP Upgrade, SLP Bilstein, LT1 Eibach ProKit, Kuhmo PA31 Tires ,SLP Fan Switch, UMI Double Adj PHB w/ Roto-Joints, UMI LCARB, Strano 35/22mm Sway Bars , Magnecor KV85 Wires, Hurst Shifter, Lou's Short Stick.
    San Diego ca
    "Arrest Me Red"
    2001 trans am
    Pro 5.0 here and love it
    "The Camaro SS looks like it could kick your ass. The Trans Am WS6 looks like its on its way over to do it."
    treat stressful situation like a dog. if you can't eat or hump it, then piss on it and walk away.
    keep your foot in it,till you see god
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    I also run the Hurst Billet. No issues.
    Old Member, New Username BrownsMillsAntz's Avatar
    Aug 2011
    Browns Mills NJ
    Green
    1995 Z28 w/ LS1 Swap
    Both are good but ive seen this question pop up several times over the years and the majority like 50
    Heads/Cam/Intake/Stall.
    404 Rwhp uncorrected @ 6400
    Coral Springs, Fl
    Sunset Orange Metalic
    Have yet to hear one complaint about the mgw. I have it and love it. Not on your list but figured id throw it in there
    Pro 5.0 with Lou's Short Stick. Love it, also almost anything is better then stock shifter.
    Which ever one you get I'd recommend using lock tight on the stop bolts. I had to go back and re-tighten after about 500 miles and many throws. Since the lock tight, no more problems.
    It goes in easy, in fact takes longer to remove the center consul then it does swapping the shifter. Also some do, some don't - run a bead of RTV to help seal it to the tranny.
  1. hurst billet/pro shifter
    By 02 Camaro SS SLP in forum Camaro / SS
    Last Post: 07-27-2010, 03:01 PM
  2. B&M Ripper Vs. Hurst Billet Plus Shifter
    By seppburgh in forum Manual Transmission
    Last Post: 11-09-2008, 09:16 AM
  3. Hurst shifter stock & hurst billet shifter
    By chadnol10 in forum Parts For Sale / Trade
    Last Post: 03-04-2007, 06:07 PM
  4. Hurst Billet/plus shifter
    By lt1dragon in forum Manual Transmission
    Last Post: 02-20-2007, 06:28 AM
  5. Hurst Billet Plus Shifter or Pro 5.0
    By 89LX in forum Manual Transmission
    Last Post: 11-05-2006, 08:56 AM
