Page 1 of 3 123 LastLast
Results 1 to 20 of 60
    Member flybird's Avatar
    Jun 2010
    Houston
    Mid Night Blue
    1999 Firebird 3.8 series
    Terrible gas mileage!!
    Ok, so I have a 99 v6 firebird. Car has 152,000 miles but the new engine has 6,000. This car is my daily driver. I am getting 11MPG!!!!! I checked for a vaccum leak but i cant find it. i know i have an o2 sensor out but i dont think it would bring my mpg that much!
    So i am thinking that maybe an additional problem besides the o2 sensor, is my fuel filter.. I noticed exhaust fumes and also the bad mileage, and sometimes hard start. those symptoms are fuel filter.
    ANY suggestions??? ps: tire pressure is okay and calipers are okay, so no drag..
    phoenix
    04 2500 4x4 crew cab
    I dont know jack about the v6's, but if it has a MAF sensor, you should clean that with MAF cleaner, and also change you air filter. If that dont fix it, change the O2's, then plugs and finally wires. It could be hard to start with a plugged fuel filter, or a going out fuel pump, but that shouldn't affect your mpg. It could also be hard to start because of fouled, or worn off plugs.
    Jun 2010
    Houston
    Mid Night Blue
    Plugs are new, they came along with the new engine. I checked the maf sensor, its clean. My k&n cold air intake is cleaned and oiled. Just one o2 sensor is out. I dnt believe it would cause a huge drop in mpg.
    Senior Member 98maro's Avatar
    Feb 2010
    north bay california
    00 camaro ss M6 #6695
    i had a similar problem on my ls1. yours is a v6 but it shouldnt matter..
    my car was also lazy, i changed the fuel filter, and plugs the car was fine..
    the o2 could be the problem too, but try to check your fuel filter, also the plugs could be the problem..what plugs did they put on?
    Jun 2010
    Houston
    Mid Night Blue
    Quote Originally Posted by 98maro:2723305
    Prestolite spark plugs. All fairly new. Maybe coil pack problem?
    Feb 2010
    i never heard about those plugs, that could be the problem too, this cars run with ac delco better some people put NGKs too, i leaned that if you put the wrong spark plugs on a car, can waist more gas than usual.
    if the motor is shaking alot, could be the coils, but if the car runs fine on idle, that is not the problem,
    change the o2 sensor if you haven't,
    also clean the MAF, i dont know alot about this cars.. just a guess
    any engine codes?
    Jun 2010
    Houston
    Mid Night Blue
    Codes tht poped up are knockin sensor defective, heated o2 sensor defective, and air temp circut I believe.
    Member transamgirl89's Avatar
    Dec 2009
    Dacula, Georgia, United States
    2001 RS Camaro
    I would seafoam it to. I had a new engine put in mine to and recently changed the fuel filter and get way better mpg. Around 23 city and 30-32 hwy
    Pittsburgh
    2008 Hummer H3
    Which 02 is bad??? You have 2 front and one rear.. If it's a front one than you can bet it's the issue..
    Jun 2010
    Houston
    Mid Night Blue
    Smittro, so glad you stepped in. I have just replaced my fuel filter, didnt do much. Im about to put in fuel system cleaner to help. The o2 sensor tht is bad is bank 1, sensor 1. Im 17 still learning, but Im not sure where that is located.
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by flybird View Post
    Bank one corresponds with number one cylinder..
    Both front 02's are located @ bottom of the manifolds just above where the "Y" pipe bolts to the mani's...
    It's a very cramped space, and unless you are absolutely sure about unbolting the "Y" I'd try to leave it be.
    Attempting to remove the bolts from the manifold can create even more problems as they are likely to be nearly rusted though as we speak..
    They will most assuredly break off if you try messing with them especially if they are the old factory ones..
    (ask me how I know)..
    If they break off it's damn' near impossible to drill them out with the manifolds still on the car..
    I drilled mine on the car and it was a total pita from start to finish there's just no darn room to work..
    I even soaked them with PB blaster for 3 days prior, then tried to heat them with a torch and they still snapped off..
    Reaching the 02's from the top is out of the question unless you can bend your forearm in the middle..lol
    Member My00Z28's Avatar
    Sep 2010
    Holland, MI/Lima, OH
    2000 Camaro Z28 A4
    the knock sensor should get replaced ASAP if it is bad, they can cause serious damage if they are not working properly.
    Heated o2 sensor is bad if its the heated o2 "circuit" then that shouldn't affect your mpg because the heated circuit only is on when the car is cold. if its the sensor its self then it can cause a huge drop in MPG
    also air temp sensor if that is bad then the computer can not tell what the temp of the air is coming in to the engine to adjust the timing of the engine and what not if that is bad replace it.
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by My00Z28 View Post
    A bad o2 on the 3800 can and will cause a knock code as the AFR gets thrown off by the faulty o2.
    The o2 should be changed first as the black smoke it can cause due to poor mixture/combustion can foul the rear o2 and plug the cat..
    3800 will run with unchanged MPG's even if the air temp sensor is unpluged it will just have a diving idle..
    Jun 2010
    Houston
    Mid Night Blue
    Hey smittro, yeah replacing the fuel filter and cleaing the fuel system did not do much..i will be getting that o2 sensor replaced sometime next 2weeks when I get paid again. I do have BLACK smoke coming through the exhaust just on the start. I will update this forum once done. Thank you everyone for the help, I much appriciate it.
    Pittsburgh
    2008 Hummer H3
    No prob..
    Bad knock sensors are not common with the RWD 3800-II.
    Again, I'd start with the 02 sensor first have the codes cleared and go from there.
    Pittsburgh
    2008 Hummer H3
    Oh dam, almost forgot, don't forget to disconnect the battery before you unplug anything.
    Once the sensor is changed reconnect the batt, and let her idle for 5-10 minutes before you take off..
    Sep 2010
    2000 Camaro Z28 A4
    but if its the heater circuit then that would have no affect of the car except when it is cold therefore would not hurt MPG o2's on any engine do not operate when they are not at a correct operating temp. thats what the heater circuit is for to raise the temp faster to get them to turn on.... no matter what i would replace them but how would the heater circuit of an o2 sensor make it so the knock sensor would trip?
    Pittsburgh
    2008 Hummer H3
    SImply put, the code would be for the heater curcuit if that was the issue, and a bank code for the sensor itself..
    If the sensor never "turns on" guess what happens to the AFR reading?
    3800-II knock sensor is block mounted and rarely if ever go bad durring the life of those engines.
    Sep 2010
    2000 Camaro Z28 A4
    if the sensor doesnt turn on then you get a "oxygen sensor no activity bank 1 sensor 1" blah blah blah if the sensor isnt working if it is just the heater circuit then you would get an "heater oxygen sensor circuit bank 1 sensor 1" and so on....
    Pittsburgh
    2008 Hummer H3
    Right!
    Both are indications of a faulty 02 sensor..
    Which currently according to the OP are abviously dirrectly effecting AFR's after the engine is warm hense the poor MPG's.
    There is nothing stated about a loss of power which would be an indication of a bad knock sensor pulling too much or not enough timing.
    Again poor afr's in turn as I already stated can/will cause a knock issue.
    If the heater curcuit is bad then the sensor is bad, if it does'nt turn on it can be assumed it also bad.
    It does'nt matter whether it's cold or hot a faulty 02 is a faulty 02..
    Target MPG's AND AFR's come after closed loop when the engine is @ operating temp, SO, if the only the heater curcuit is bad then MPG's nor AFR's would not be effected once the designated temp was achieved as it could be assumed the sensor is working aside from the heater curcuit..
    The odds of an 02 and the knock going bad @ the exact same time are slim @ best.
    If it's the knock sensor then I'll eat my hat..
    But I am confident once the 02 issue is corrected the knock sensor code once cleared will not return..
  1. Help: TERRIBLE GAS MILEAGE!! Really upset..
    By flybird in forum Firebird / WS6
    Last Post: 02-16-2012, 07:16 PM
  2. Terrible Dyno
    By 99formulals1 in forum Firebird / WS6
    Last Post: 04-25-2008, 10:30 PM
  3. TERRIBLE Gas mpg
    By Speed_kills_WS6 in forum General Help
    Last Post: 02-15-2008, 03:39 PM
  4. terrible fuel mileage
    By Dennis McInroy in forum General Help
    Last Post: 07-02-2007, 09:26 PM
