Results 1 to 17 of 17
11-27-2011, 06:15 PM #1
Whats the best adjustable torque arm to buy
I just got a 9 inch rear and now i want to change the torque arm and was wandering who made the best for the money.
11-27-2011, 06:20 PM #2
You can go with a UMI adjustable unit. Depending on what you want, you can go with a tunnel mount or full-length. Full-length is geared towards street driven and a tunnel mount is geared towards the track.
Either way, I'd suggest getting one that mounts off the tail-shaft of the tranny.
What do you currently have on the car?
11-27-2011, 06:30 PM #3
I have the factory one but was looking at the torque arms that relocate
11-27-2011, 06:31 PM #4
11-27-2011, 06:34 PM #5
Well most people on here use UMI products and are very happy with them.
I run the BMR TrakPak adjustable torque arm set-up with my Moser 9" and I had issues with the cross-member brace which the front of the torque arm mounted to. It dipped down too low (designed that way for exhaust clearance) and it scrapped on the ground going up steep inclines and over speed bumps. I had a fabricated heat it up and bend it upwards for more clearance.
I am lowered on Strano springs though, which is about a 1.2" drop.
I'd wait to see what others say about the UMI relocation brackets for the torque arm. I've seen a few here that have them and they also scrap because they are lowered.
If you are not lowered, you probably won't have an issue with any one you choose.
11-27-2011, 06:35 PM #6
11-27-2011, 06:39 PM #7Slow'er'Ass
- Thornton, CO
Mine had Strano springs and I never once touched that cross member....
Differing driving style I imagine, but I would rather scrape once in a while over having the transmission tail taking on unneeded stress.
Unless of course UMI changed the design from the one I had to the one you had....
EDIT: Caught your last post. Yes, OFF OF the tranny is a good thing.
11-27-2011, 06:45 PM #8
I run the BMR unit, which was a solid bar that ran from one sub-frame connector to the other, and welded to each. There was a dip in the bar where the exhaust ran through for clearance. Once I was lowered, that dip became an issue. Not sure how low the UMI one's hang. Just remember seeing a few here with them that scrapped. They could have been running another name brand spring that made them slammed lower than our set-ups.
11-27-2011, 06:54 PM #9
I have the UMI tunnel mount for the track and it works great. However, on the street it transmits quite a bit of noise into the cabin by the way it is mounted. I also had an issue in that I could not use the upper mounting points with my PST driveshaft -- no clearance at all. As stated, for the street stick with a full length torque arm and get it "off" the transmission.
11-27-2011, 06:58 PM #10Senior Member
- May 2010
- Wilkes-Barre, PA
Black/Black- 98 WS6/04 Sierra Dmax
I have the UMI Tunnel Brace Mounted Torque Arm w/ DSL. I had the set up for the long tube headers, I was lowered with eibach pro kit and it scraped every where. I only had it on there for maybe 50 miles, I ordered the mount for the stock manifolds and it cleared my ORY without a problem.
11-27-2011, 07:40 PM #11
im running the umi torque arm and relocation braket and love it. My exhaust is sitting right on it but it clears and im running ORX. No complaints here and i have mine lowered and so far no road noise and no dragging and my car has the RS package. UMI the way to go.
11-28-2011, 07:17 AM #12Member
- Jan 2009
- Pa
11-28-2011, 10:47 AM #13
I have the moser 9 inch rear, does that make a difference , plus I have pacesetter long tubes and Texas speed carted y pipe with borla exhaust
11-28-2011, 11:53 AM #14Spaz is My Mentor
Lowrider we are very simular.
I'm running UMI TA Part # 2205 with a relocate kit (for manual transmission) Part # 2207.
It is great for both track & street driving and will be able to handle the 9".
It takes the TA off the tail cone while the relocate kit swaps out the stock cross member for the tranny to sit on and relocates the TA just aft of the cone.
Here's some pics
11-28-2011, 11:54 AM #15Spaz is My Mentor
No problems with Hotchkis 1" drop springs, Pacesetter LT's with TS& P ORY.
11-29-2011, 07:47 AM #16Member
- Jan 2009
- Pa
Hey Scott. Thanks for posting that good info up there ^.
ramey
11-29-2011, 11:04 AM #17Spaz is My Mentor
Op,
Also here are a couple of vids to show how straight I launch out after installing the UMI stuff (Adjustable PHB/TA/LCA, TA relocate kit & TSB) I used to kick out a little to the right when I had stock suspension. Now it is straight as an arrow.
this was on Nitto NT555's - I had some wheel spin in the box, I know DR's will fix that issue for next time.
Ramey - no problem
Adjustable or Non-Adjustable Torque Arm?
By Naaman in forum Suspension and HandlingReplies: 5Last Post: 09-18-2016, 11:03 AM -
WTB Adjustable Torque Arm
By 1997 TA in forum Parts Wanted / TradeReplies: 0Last Post: 04-16-2009, 03:52 PM -
Adjustable Torque arm?
By LETHALxLS1 in forum Suspension and HandlingReplies: 28Last Post: 07-05-2007, 07:10 AM -
SLP Adjustable Torque Arm
By retriever in forum Parts For Sale / TradeReplies: 16Last Post: 04-21-2006, 01:17 PM
"off" of it. Not off as in on it
