Results 1 to 10 of 10
    Nov 2011
    tupelo
    blue
    99 ss camaro
    99 camaro makes noise
    i just bought a SS camaro with 85,000 miles it makes knocking like noise when i first start it up but then it seams to stop after it runs for a min. the guy said that all ls1 make noise this is the first ls1 that ive been around got a 95 camaro with a 383 lt1 dont know alot about the ls1 does all ls1 make noise if not what mite it be?
    Member WS6SP33D's Avatar
    Nov 2011
    QuarterMile, KY
    Red w/ silver Stripes
    2000 WS6 6 Speed
    Piston slap is my first guess and second guess would be valve train. Yes ls1's are commonly loud motors when it comes to making noise.
    Nov 2011
    tupelo
    blue
    99 ss camaro
    will a piston or rod fly out would you spray it with piston slap??if so what would be to much??would putting pistons in it break the bank
    Nov 2011
    QuarterMile, KY
    2000 WS6 6 Speed
    Quote Originally Posted by samuel99 View Post
    No im not saying you need pistons. Almost every ls motor that comes in my shop and i have delt with has piston slap. But as motor gets hot they expand and it quits making the noise. And i am not understanding spray it with piston slap?
    My guess is he asked if it would be ok to add a nitrous system to it.
    OP: As stated, our engines are notorious for being noisy when cold. The combination of a short skirt piston and different material expansion rates results in "piston slap". This noise generally goes away as the engine warms up and should be non-existent when hot. The valve train is also known for a "sewing machine" type noise. Our car has both and it's just a fact of life with an LS1. Just be sure to warm the engine up before playing with the loud pedal and you'll be fine.
    Nov 2011
    QuarterMile, KY
    2000 WS6 6 Speed
    Oh ok thanks Jeff i see now lol. I was on my phone at the shop and couldn't understand it. But i see now.
    Nov 2011
    tupelo
    blue
    99 ss camaro
    what is the best oil and filter to use the guy i bought the car from told me thay changed the oil but he didnt say what kind of oil and the sticker on the windsheld just has the miles for the next oil change what about lucus oil stablizer
    Nov 2011
    QuarterMile, KY
    2000 WS6 6 Speed
    You you search there are plenty of opinions on oil threads here. I use mobil1 5w/30 and mobil1 filter. Not big on the use of stabilizers.
    Drop&Drag matt evans's Avatar
    clyde nc
    02 Z28 and 00 SS
    all the ls motors in my shop have the piston slap and Zinger sewing machine valvetrain sound going on. Only way to not hear it best i can tell you is to get some loud exhaust. Like the others said before once it heats up your fine.
    We have a couple of good threads on oil and filters. I think the top rated filter right now is the Fram Xtended Guard (believe it or not), with Amsoil, Wix (same as Napa Gold), Mobil1 and others also being preferred. Good oils include Amsoil, Mobil1, and Penzoil Platinum. Opinions vary quite a bit on this topic.
  1. Help: z28 camaro makes popping sound
    By dany3350 in forum General Help
    Last Post: 01-06-2013, 06:18 AM
  2. Help: 2000 pontiac trans am makes a popping noise when s
    By edrvsqz1980 in forum General Help
    Last Post: 05-26-2009, 03:13 PM
  3. My new KYB strut makes a creaky noise in rain only
    By BlackZ28629 in forum Suspension and Handling
    Last Post: 11-11-2006, 07:21 AM
  4. Who makes the best halos for camaro?
    By OneslowZ28 in forum Appearance Section
    Last Post: 11-08-2006, 01:40 PM
