Results 1 to 19 of 19
Thread: Oh shit moment
11-17-2011, 10:18 PM #1
Oh shit moment
bought my goat this year with 48k on it for a steal. the only issue is that the dealership that i purchased it from did not have the key to my rims purchased by its previous owner. i have looked everywhere and no one has a fitting key for them. my baby is in storage right now while im deployed, and my wife maintains its fluids and runs it every here and again. my issue is how im going to rotate/ replace tires whenever the time comes... and suggestions???
11-17-2011, 10:36 PM #2Senior Member
- Feb 2010
- north bay california
Black- 00 camaro ss M6 #6695
take it to a tire shop they should be able to remove it... usually is $5 per lock
11-17-2011, 10:51 PM #3
11-17-2011, 10:55 PM #4Senior Member
- Feb 2010
that is going to hurt even more! i will recommend you not to watch that when they are doing it ahha jk..
i have done few of them, it doesnt damage anything. unless the bolt is rusted.. it could break..
11-17-2011, 10:59 PM #5
What brand lugs? i have had customers have to call gorilla and get a replacement key. But they were also the original buyers of the lugs. It's worth a shot for you. Also some parts stores carry a universal key to certain brands. I know it kind of take to point from having locking lugs away but they do.
11-18-2011, 02:32 AM #6
$5.00 per lock beats the snot out of drilling each one and replacing the stud.
11-18-2011, 03:20 AM #7Senior Member
- May 2010
- Wilkes-Barre, PA
Black/Black- 98 WS6/04 Sierra Dmax
I got the tools to remove them. Doesn't damage anything.
Callies 383, Trick Flow 225, Rapid Motorsports Dominatior 2 X cam, ls6 ported oil pump,42lb injectors, FAST 92/92 , ASP underdrive pully, eletric water pump, Pacesetter LT's, Pacesetter ORY, Magnaflow catback, e-cutout, Yank SS 3600, Performabuilt stage 2 4l60e, Strange S60 ,4.10s, Detroit Truetrac, (UMI) - Adj. LCA, Adj. tunnel mount torque arm, Adj. panhard bar, Drag bar, subframe conectors, shock tower brace. 465rwhp-438rwtq [email protected].
11-18-2011, 04:37 AM #8
^ yea there shouldnt be any issues getting them off.
98 ws6 stock short block 228r ls6 Heads Fast 102 tick level 2 trans monster stage 3 mwc 9 on the way
11-18-2011, 06:57 AM #9Senior Member
- May 2010
- Wilkes-Barre, PA
I don't know if this picture is gonna show up, but here is the tool I have. It's from snap on, you hammer it on the lock and rip it off with an air gun.
11-18-2011, 09:36 AM #10Senior Member
- Oct 2008
- Coral Springs, Fl
Ive lost the key to mine before, they are extremely easy to take off, pick up a socket that barely doesn't fit and hammer it on, then use a breaker bar to remove them
11-18-2011, 05:29 PM #1111 years of bangin gears
- Jan 2009
- North Jersey
I agree with Jeff and Alex. I have hammered sockets over locks and they have come off quite easy with a breaker or my impact gun.
11-18-2011, 05:32 PM #12You've Seen The Butcher
- May 2009
- Indiana
2009 Silverado Z71- 2003 Corvette MN6 Black
The Dealer I bought my Camaro from didn't have the key for the rims.. I called and called about it and they never called back. Finally I just drove over there and said, "The car didn't come with the key for the lugs, what are you going to do about it" Luckily for me they went ahead and just replaced the locks with regular lug nuts, which was fine by me (I don't think anyone wants to steal 16'' Z28 rims lol) But then again, it was only about a month after I bought it too.... If they hadn't of fixed it, I would have tried jamming a socket on there and getting it off that way.
11-18-2011, 08:17 PM #13
i will def try that when i get home. that has been wearing heavily on my mind for some time now. i also went to every tire shop in my area and no one had the key to solve my issue. i hope this doesnt prove to be problematic.
11-19-2011, 06:21 PM #14Senior Member
- Apr 2008
- Madison, WI
Go to sears, buy a 12pt chrome socket (size depends on which brand lock you have) that you can pound on the lock and take it off with a breaker bar or impact gun. Thats what I do. The locking lug nut will be stuck in the socket, so you'll have to pound it out with a punch or screw driver. I've also spun them off with an air hammer with a chisel bit.
Also, any shop can remove locking lug nuts, so if you don't want to that is an option.
11-26-2011, 06:53 AM #15
Once they're off I'd just leave them off. I don't dd my car any more but I took mine off a long time ago.
12-02-2011, 10:37 AM #16
Pick up a set of cheap lug nuts and weld them on the locks..
Them throw them away and replace..
Works every time..
12-02-2011, 05:45 PM #17Senior Member
- Apr 2008
- Madison, WI
That'll work too. Never thought of that one.
12-04-2011, 10:04 AM #18
12-08-2011, 06:18 AM #192001 Camaro SS, LM 1, BMR LCA, relocation brackets, BMR springs, adj panhard bar, smooth below, lid, sub-frame connectors weld on, strut brace
2000 WS6, ls6 intake, sub-frame connectors, slp maf, slp cat delete with slp y-pipe, electric cutout, strut brace, smooth below, slp lid, bmr LCA and RLB
That moment when.....
By Trooper182 in forum General HelpReplies: 7Last Post: 03-07-2017, 05:47 PM -
Most Embarrassing WS6 moment EVER
By Intrepidman in forum Almost Anything GoesReplies: 13Last Post: 03-27-2009, 08:37 PM -
Moment of truth
By redls1 in forum Almost Anything GoesReplies: 9Last Post: 02-19-2008, 06:54 PM -
Moment of Truth...
By PureSShp00 in forum Almost Anything GoesReplies: 26Last Post: 02-01-2008, 05:03 AM -
My $6, spur of the moment mod
By Kamauxx in forum Appearance SectionReplies: 15Last Post: 11-06-2007, 10:08 PM
