Thread: Rattles and bangs.
11-17-2011, 07:03 AM #1Member
- Sep 2011
- England
Rattles and bangs.
Hi everybody,
I know that F-bodies tend to have their share of rattles and bangs, (probably due to its stiff suspension and the UK's crappy roads), but I can live with them. My concern is that I might ignore something which shouldn't be ignored. Would you guys investigate and silence all the rattles or not?
There is one issue that may or may not be anything to worry about. The driver's window when fully in the down position, will sometimes rattle. Is this something that urgently needs to be done?
As always, all input welcome.
11-17-2011, 07:25 AM #2None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Depending on the severity of the noise, I would investigate. Check all suspension componants for tightness, exhaust piping for tightness and contact with suspension or chassis, motor and tranny mounts, ect.. I really don't experience any rattles in mine, but pretty much everything is aftermarket and adjustable. I would remove the door panel, carefully, and check the window track and window for contact with anything. One of the bolts might be slightly loose, or something fairly simple.
11-17-2011, 07:53 AM #3Spaz is My Mentor
Walt's right
In addition I'd add any noise under the shifter. I had the bolt that secures the Torque Arm to the tail cone back off while on the hwy. Noise was unbearable. I thought I brook my drive shaft at first.
You can usually tell after a while what is normal and what is not.
The more I drive my cars the more I'm in tune with them.
11-21-2011, 08:24 AM #4Member
- Sep 2011
- England
Thanks guys, I don't think there's anything severe, but I will take a precautionary look to make sure everything is nice and tight.
My speaker rattles
By karpetcm in forum Stereo and ElectronicsReplies: 9Last Post: 03-01-2009, 03:44 PM -
clunks and rattles
By RealLiveMD in forum Suspension and HandlingReplies: 4Last Post: 02-10-2009, 07:17 AM -
Rattles in the back
By RealLiveMD in forum Suspension and HandlingReplies: 12Last Post: 10-25-2008, 04:40 PM -
ORY Bangs against body - too much torque...
By Castle in forum External EngineReplies: 4Last Post: 01-01-2008, 10:08 AM
