Thread: New LS1 owner
11-07-2011, 07:13 PM #1Junior Member
- Nov 2011
- Oklahoma
black- 1999 Trans Am
New LS1 owner
Ok just bought my trans am 70,000 miles its a formula has a jet chip 80mm throttle body and a spacer aftermarket intake. what are some preventive maintenance i should do and what are some inexpensive mods i can do im going to install 3.73 gears, an oil cooler, and maybe a bigger cam idk give me some idea's its just a formula but might upgrade to ram air.
11-08-2011, 04:27 AM #2
Congrats! Sounds like you have an A4, so definitely a fluid and filter change on the transmission. Other basic maintenance would include cleaning the MAF and throttle body, replacing the air filter, plugs and wires, changing the engine oil and rear diff gear oil, flushing the cooling system and changing hoses and belts. Also, not a bad idea to carefully inspect things like the sway bar end links, ball joints, and tie rod ends. I would install a trans cooler before an oil cooler.
11-08-2011, 10:22 AM #3
Welcome to the site, Gabriel.
11-08-2011, 10:32 AM #4
Welcome to the site. Details on car? Pics? pajeff02 hit it right on the dot with the first things to do after buying a car. When it comes to mods on these cars most start with lid (sounds like you have) then headers (big increase in power). Dont know what year you have but 00 or older and you could do a ls6 intake upgrade. After most get full bolt ons it's time to start with h/c/i. Gears would also be a big help.
11-08-2011, 11:04 AM #5Old Member, New Username
- Aug 2011
- Browns Mills NJ
Green- 1995 Z28 w/ LS1 Swap
Get some headers, intake and loose that Jet chip junk and get a mail order
Heads/Cam/Intake/Stall.
404 Rwhp uncorrected @ 6400
11-09-2011, 09:13 PM #6
Dont go with the ram air. The hood is heavier and you wont gain a thing by having it.
Exhaust, gears, cam, converter, tires (goodbye 10-bolt), and you have a fun car. Pics?
New GTO owner
By AaronJohnDuncan in forum GTOReplies: 5Last Post: 11-17-2009, 05:52 AM -
New LS1 owner from SC
By tvaughn in forum New Member IntroductionsReplies: 1Last Post: 09-06-2008, 04:43 PM -
New WS6 Owner
By mrsracing in forum Firebird / WS6Replies: 44Last Post: 06-21-2008, 10:19 AM -
new to me t/a owner
By chrisjordan in forum New Member IntroductionsReplies: 2Last Post: 03-26-2007, 03:16 PM -
'99 TA Owner
By h0rsepwr in forum New Member IntroductionsReplies: 1Last Post: 03-26-2007, 08:54 AM
