Thread: Stumble
10-29-2011, 05:25 PM #1Junior Member
- Oct 2011
- Alanama
Red- 97 trans am
Stumble
When my car is cold and idling up to warm up it stumbles doesn't stall but acts like it's runnig out of fuel. The deco pump is fairly new what's up with that??
10-29-2011, 06:08 PM #2None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Check the fuel pressure at the rail, you should see 58 psi. You could also try cleaning the MAF, as that could be a possible cause as well. I take it you aren't getting a SES light?
10-30-2011, 05:24 PM #3Junior Member
- Oct 2011
- Alanama
Red- 97 trans am
No trouble code When it warms it's fine. 58lbs for lt or ls mine is lt. If pump is bad it's under warranty would you recommend a racetronic??
10-30-2011, 06:06 PM #4None Shall Pass
- Jan 2010
My mistake, I didn't catch you were a LT1. With the vacuum line disconnected from the regulator and plugged, you should see around 41-47 psi. With the vacuum line attached, it will vary. I'd expect around 35 psi or so. If you can monitor the pressure while driving, you should see nothing less than 40 psi.
I've heard Racetronics are good, as well as Walbro.
11-01-2011, 04:06 PM #5Junior Member
- Oct 2011
- Alanama
Red- 97 trans am
Ran it today but let it warm up first. I got on it hard and it did fine. Reckon why it only cuts out when cold. By the way the opti- spark is gone I've got a msd distributor.
11-01-2011, 06:29 PM #6None Shall Pass
- Jan 2010
Hmm.....wonder if it's not an O2 sensor problem if it's only while cold. Strange you aren't throwing a code, although you could have it scanned to see if one is pending.
11-02-2011, 05:17 AM #7Junior Member
- Oct 2011
- Alanama
Red- 97 trans am
Scan it while it's cold??
11-02-2011, 05:23 AM #8None Shall Pass
- Jan 2010
Cold or warm. Sometimes there will be a code pending that won't throw a SES light.
11-02-2011, 05:28 AM #9Senior Member
- Nov 2006
- Indianapolis
Remember the PCM mostly ignores 02 sensors until the engine is warm.
OP, have you ever had your injectors cleaned? The engine is supposed to run fat (rich) until over aprox. 160*. If they are partially dirty, that may show up like this. Also, deposits on you intake valves can cause this.
11-02-2011, 05:58 AM #10
11-02-2011, 06:51 AM #11
Also, its almost 20 years old. How is that fuel filter?
11-07-2011, 04:34 PM #12Junior Member
- Oct 2011
- Alanama
Red- 97 trans am
Fuel filter is pretty new but after it warms up it's fine. Wot no prob idle no prob cruising no prob. Just when cold and idled up
Stumble around 50mph.
By fbody23100 in forum LT1Replies: 7Last Post: 02-22-2016, 09:22 PM -
Stumble problem
By camarostripes96 in forum LT1Replies: 5Last Post: 12-26-2008, 09:21 PM -
Help: Engine Stumble
By Wesman in forum General HelpReplies: 13Last Post: 07-20-2008, 10:50 AM -
Misfire or Stumble?
By Z28er in forum General HelpReplies: 0Last Post: 07-07-2008, 10:52 AM -
Stumble??
By griftymcgrift in forum External EngineReplies: 5Last Post: 11-01-2007, 04:00 PM
