Results 1 to 13 of 13
    Member RedHot99T/A's Avatar
    Jul 2010
    Albany,NY
    1999 Trans Am ws.6
    9inch and gearing
    Lokking into buying a 9inch rear and just want to know what will i need for install,and what damn gears to go with im torn between 4:11 or 3:89's im so confused to whats better for me.i have a 6-speed and heads/cam/intake and eventually gunna do a stroker in a few years,its driven on a few longer drives once and awhile and im looking for fun but dont want to lose the highway drivabilty to much.any info/opinions are welcome.
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    M6? Go with the 4.11's
    Forged 383 | ATI D-1SC
    NX MAF Kit | 222/226 .585 115
    AS Stage II 6.0L FI Heads
    Jul 2010
    Albany,NY
    1999 Trans Am ws.6
    Oh yea! It is a m6
    East of Cleveland, Ohio
    99 WS.6 - Modified
    You will need an adapter u-joint for the driveshaft to mate to the pinion yoke. Also, many choose to upgrade to an adjustable panhard bar, lower control arms and relocation brackets, torque arm, ect. Depending on where you purchase the rear from, some of these options are available when you order. You may also need to install your backing plates on the axles, and have the axle bearings pressed on. Reluctor rings too, if you are retaining abs/tcs. They can usually be installed from the factory as well, if you choose.
    Jul 2010
    Albany,NY
    1999 Trans Am ws.6
    i knew about the ujoint,so it would deff be good to upgrade all of that...do they all have t be adjustable?
    99 Ws.6-Hooker LongTubes,Ms4Cam,Polished 243 w/3angle valve job,MTI Clear Lid,P/P ThrottleBody,F.A.S.T Intake,31lb Injectors,EGR/PCV Delete,3inch True Duels W/Magnaflow Mufflers,Duel E-Cutouts,Weld In SFC,Stage3 ACT Clutch.
    99 WS.6 - Modified
    I would suggest at least the panhard bar. The rest will depend on the main goal for the car.
    Jul 2010
    Albany,NY
    1999 Trans Am ws.6
    ok,well it will be at the track atleast 6-8 times a season...so i might as well save and do it right with the suspension parts....
    You'll want adjustable components if you are lowered or plan on lowering your car in the future.
    Jul 2010
    Albany,NY
    1999 Trans Am ws.6
    Alright,I do plan on lowering I have all the shocks/springs already
    99 WS.6 - Modified
    Adjustable is the way to go then. I always prefer adjustable anyways, but that's just me.
    Marylandistan
    2001 Trans Am (sold)
    You don't lose any highway drivability w/4:10s.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    With 4:10's you may lose 15 mph on your top end. So you can do 155 instead of 170. But the bottom end is going to be awsome.
    Jul 2010
    Albany,NY
    1999 Trans Am ws.6
    hmm well im being sold on the 4:11s..lol nowhere to got hat fast here neway i love the accel better...
  1. Help: Moser 9inch axel install!
    By seth_12 in forum Drivetrain
    Last Post: 08-07-2011, 07:11 AM
  2. 411 gearing in a 9inch
    By Rk ws6 in forum Drivetrain
    Last Post: 08-19-2009, 05:06 PM
  3. 9inch 4.56
    By zmg00camaross in forum Drivetrain
    Last Post: 02-05-2009, 04:10 PM
  4. 9inch Rear End
    By doc78 in forum Parts Wanted / Trade
    Last Post: 05-01-2008, 07:45 PM
  5. 9inch or 12 bolt?
    By farm12340 in forum Drivetrain
    Last Post: 09-06-2006, 03:25 PM
