Thread: Msd coil pack?
10-26-2011, 12:30 AM #1
Msd coil pack?
My car currently has MSD ignition system. It was installed by the previous owner. I have been having a misfire issue that occurs randomly. after changing the plugs and wires it got alot better but still occurs intermittently. I am pretty sure it is a coil pack because one of them is split open, exposing the electronics to the air. I want to know if I should bother replacing all the packs with msd ignition coils (they are $100 apiece) or the oem coils which are $40 apiece. If it is just a small difference I would rather go with the oem as $800 is alot to spend on coils. Does MSD coils make a big difference in power?
2000 Z28 Pewter, M6, T-Tops, K&N Intake, LS6 Manifold, SS Hood, MSD Ignition, Magnaflow Cat-Back, Stage 3 Clutch, Short Shifter.
10-26-2011, 04:49 AM #2None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
OEM coils will work just fine.
10-26-2011, 06:38 AM #3Senior Member
- Oct 2008
- Coral Springs, Fl
Not worth the money, oem should work fine
10-26-2011, 09:29 AM #411 years of bangin gears
- Jan 2009
- North Jersey
Unless your engine is fully built(Heads/cam/intake/forced induction), then just go with the OEM coils.
10-27-2011, 07:36 PM #5
oem coild are good hard to beat. call your junkyards for wrecked 5.3 trucks those coils will work as well and you can save some money to.
Coil Pack Question
By Ls_won in forum General HelpReplies: 31Last Post: 06-13-2011, 06:39 PM -
bad coil pack?
By Mikat1 in forum External EngineReplies: 2Last Post: 05-03-2011, 09:14 PM -
Wanted: LS2 coil pack
By crazykracing2 in forum Parts Wanted / TradeReplies: 1Last Post: 04-13-2010, 12:41 PM -
coil pack ?
By t-rock in forum LT1Replies: 6Last Post: 12-28-2008, 06:48 AM -
Wanted: Need LS1 Coil Pack's
By yellowlt1ta in forum Parts Wanted / TradeReplies: 3Last Post: 11-09-2008, 06:27 AM
