Results 1 to 18 of 18
Thread: oil level
    Junior Member Karczewski's Avatar
    Oct 2011
    Alabama
    oil level
    Hey, I'm new to the v8 club, and was just wondering if this is a problem I need to fix or not. When I'm in idle the oil gauge is a little over the middle line and when I drive it gets to 3/4 of the gauge and gets higher as I go faster.. is this normal? I have a 2001 trans am btw
    Pittsburgh
    2008 Hummer H3
    I'd say normal..
    Oil presure rises with rpm in all engines..
    Oct 2011
    Alabama
    Ok good. Cuz I had a v6 but the oil pressure was always low in idle cuz I had my cats taken off. So I wanted to be sure before I kept driving the way I do, Haha
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    I red line that gauge when I red line the tach. Does the same in the Jeep.
    The gauge isn't completely accurate anyways, just a rough idea, as long as you have pressure, you'll be ok.
    Wisconsin
    2001 Camaro SS M6
    As long as your pressure isn't almost near the bottom you are good. The gauge is far from perfect and only a tool that will assist you in determining a rough estimate. If your pressure keeps dropping then you need to worry about something that is happening in the engine. As stated before, as rpm's rise then so shall the oil pressure. Cats taken off a car shouldn't effect oil pressure FYI, two totally different things. I believe as long as you have 20 psi of pressure at idle then the LS1 is fine. Someone can correct me if I'm wrong but I'm 95% sure on it.
    Op where in AL are you?
    Oct 2011
    Alabama
    Close to huntsville
    I asked becasue we have several 'bama members here. I'm near Mobile
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    I also say you're good. I have a buddy who lives in Huntsville.
    Oct 2011
    Alabama
    Haha, cool. Didn't know there would be some bama people here, Haha
    Centerville OH
    blue
    1999 TransAm
    mines at like 20psi at idle... i think it's been that way ever since i can remember... normal cruising/operation it ranges between 20psi and maybe 50psi - i drive like a granny
    Oct 2011
    Alabama
    Haha, I have a heavy foot
    I start work at 5 and it takes about 30 min to get there but I sleep til 430 and I'm rarely late
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    A good rule of thumb is 10psi for every 1000RPM. If you have that or more, you're fine.
    Centerville OH
    blue
    1999 TransAm
    starting from zero, i assume?... meaning idle speed would be maybe 7-8 PSI? i don't think i've ever seen my guage go that low..
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    The LS1 can live with as little as 7psi under a light load but 30psi and above is it's happy place. Bearing wear, oil weight, temp and the gauge all have some effect on oil pressure.
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    Quote Originally Posted by Karczewski View Post
    Keep in mind that the gauges in our vehicles are "electrical" not mechanical, so in other words you are just getting a general idea of what the oil pressure is, vice a precise reading that the mechanical gauge will give you.
    SteveC
    Quote Originally Posted by SteveC View Post
    SteveC
    True with the exception that 98's are the only yr that the gauges are mechanical. Also we are the only yr that has no sail panel issues.
    I don't have any sail panel issues and I'm an 02
    Edit: I own a Camaro though, not a Trans Am
  1. level 3 trans vs a level 5 rebuilt kit
    By FMR_TransAm in forum General Help
    Last Post: 03-18-2012, 09:13 PM
  2. Low Oil Level
    By thor2001TA in forum Internal Engine
    Last Post: 12-13-2011, 03:07 PM
  3. TODAY SALE, LEVEL 2 $100 OFF, LEVEL 3 $300 off
    By performabuilt in forum Automatic Transmission
    Last Post: 05-21-2008, 01:47 PM
  4. oil level sensor
    By 96 ta in forum LT1
    Last Post: 12-09-2007, 12:29 PM
  5. Sea Level???
    By SPLIT THIS in forum Drag Racing
    Last Post: 05-30-2006, 07:04 PM
