Thread: Ses light
    REAPER Z28 reaper ws6's Avatar
    Apr 2009
    Tyler TX
    Navy Blue Metallic/Black
    02 camaro z28/01 wife t/a
    Ses light
    Went to scan my car today and i got this code P0702 witch means transaxle actuator lost power. What is a transaxle actuator and what does it do? also what can be causing this problem?
    also my interior lights pulse could it be related?
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Think it's something to do with the transmission, not positive.
    An A4 I'm assuming?
    Is it shifting ok?
    Jul 2009
    Custom Swirly Black
    2001 WS6 M6
    Googled from a Saturn site (I assume to be similair since they're GM):
    "The transaxle is a fully automatic unit consisting of four multiple disc clutches, a four element torque converter with a lock up clutch, 1st gear sprag clutch, and a servo actuated dog clutch.
    The most significant departure from the traditional automatic transaxle comes from the use of electronic controls. This unit utilizes five electrohydraulic actuators in conjunction with a powertrain control module (PCM) and its sensors to control shift timing, shift feel and provide on-board diagnostics.
    The transaxle control actuators are electrohydraulic solenoid valves consisting of a housing, valve body, sliding armature and electromagnetic coil.
    The actuators are located in the transaxle valve body."
    I assume time, faulty parts, used fluid, etc is the likely cause of this.
    As far as fix for this, I am no transmission expert, so I got no help.
    Apr 2009
    Tyler TX
    well is a M-6 car still drives good and shift's good, the only thing is wen i shift and the rpm's are like at 15k the car kinda bucks like if im not giving enough throttle and sometimes wen im like in 3rd around 2k rpm's and i let of the gas it engine breaks really hard but then it stops and goes back to normal.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    I don't know if it is the equivalent to a vehicle speed sensor. If it is, then it could be shorted out.
    Member DaddySS's Avatar
    Bergen Co. NJ
    2000 Camaro SS Conv.
    Can yolu verify the code - you should not get a 0702 code with an M6. 0702 is transmission control - electrical - and an M6 doesn't have it.
  1. Tail Light, Head Light Lens Cleanup, Body Work Questions
    By MAXX2 in forum Appearance Section
    Last Post: 12-15-2010, 08:15 AM
  2. light up middle tail light bird
    By trans_am7935 in forum Firebird / WS6
    Last Post: 05-28-2009, 07:59 AM
  3. Adjustable Timing Light - Light Up Performance
    Last Post: 03-23-2009, 06:50 AM
  4. C5 Z06 - CAGS light as a shift light
    By rbartick in forum Computer & Tuning
    Last Post: 04-14-2008, 03:26 PM
  5. Bud Light, Coors Light or Miller Lite?
    By Hurley711 in forum Almost Anything Goes
    Last Post: 05-26-2007, 01:21 PM
