Thread: Holy Mess!
    LSwut tep98ws6's Avatar
    Jun 2009
    Saint Louis, MO
    Arctic White & Black
    '98 WS6 M6 - SWAPTIME!
    Holy Mess!
    I just started tearing down my LS1 this week. I found one HELL of a mess.
    First, I found coolant nearly coming out of my lid.
    This is kind of looking into my intake
    Looking into the intake, closer
    This is what came out of the intake ... yuck, oil and coolant cocktail
    This is what I dug out of the oil/coolant cocktail ... I had a chunk of piston (with a ring still attached), #3 exhuast valve & bent stem and a few different rings.
    PART 2 ---> The Driver's Side Cylinder Head
    #3 Exhaust rocker arm failed. It spit little needle bearings everywhere, shot out both sides of the rocker arm and ate up my valve spring.
    I have more pictures but for some reason, it won't let me upload them
    Needless to say, I'm pretty interested to see how the cylinder held up, if at all.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Yep. Engine went-->
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    Damn, that's some awesome carnage....I recommend the Trunion Upgrade on those rockers when you start putting everything together.
    East of Cleveland, Ohio
    99 WS.6 - Modified
    A little Marvel Mystery Oil will fix that right up
    Looks like you've got your work cut out for you!
    Senior Member Lunatikgixxer's Avatar
    Mar 2010
    St Pete, FL
    Bat mobile black
    2000 Trans am WS6 M6
    duct tape........ lol that does look messy howd that happen?
    James Bond Spikito's Avatar
    2001 3.8 Black - sold
    2000 SS Black M6
    this is why im scared of needle bearings....and the rockers i want to use have them...ugh
    Jun 2009
    Saint Louis, MO
    I don't know where it started, I'm assuming the piston wobbled apart due to timing issues (/bad tune), made its way up into the head, did some work up there and finished in the intake. So far, it doesn't look like much is salvagable. Luckily, im doing a swap instead of rebuild. I still want to see the inside of the block and see if the cylinder, crank and rods are still there but I was definitely surprised when I found all that in my intake. Haha
  1. Dont Mess with this kid, he'll mess you up
    Last Post: 12-11-2009, 05:17 PM
  2. How do you get a job and mess up EVERYTHING?!
    By I.B. Pimpin in forum Almost Anything Goes
    Last Post: 11-15-2009, 07:31 PM
  3. So almost had to mess this guy up unfor!
    By blackSS01 in forum Almost Anything Goes
    Last Post: 10-03-2009, 08:50 PM
  4. Haha you mess with the best.....
    By FSANE in forum Almost Anything Goes
    Last Post: 10-17-2007, 09:16 AM
  5. really how much does having your AC on mess with HP?
    By greatwhiteZ28 in forum Dyno Information
    Last Post: 09-07-2007, 10:06 AM
