Results 1 to 17 of 17
Thread: shock install question
10-19-2011, 09:34 PM #1Senior Member
- Apr 2010
- Alabama
I just finished installing my rear shocks/springs and I have a question. On ls1howto it never says how tight to tighten the top shock nut. How tight is good? I tightened it until it started clamping on the rubber piece, is that good enough?
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
10-19-2011, 09:55 PM #2Senior Member
- Feb 2010
- north bay california
Black- 00 camaro ss M6 #6695
i did this few weeks ago,, i did till the nut stop spinning..
ls1howto has a great writeup on that,, thanks to that i got it done.
10-20-2011, 05:50 AM #3Senior Member
- Apr 2010
- Alabama
Okay I guess I need to tighten it some more, although one side is already digging into the rubber.
10-20-2011, 06:02 AM #4
Look for the torque specs, than you can't go wrong
Sent from my DROIDX using Tapatalk
10-20-2011, 10:28 AM #5Senior Member
- Apr 2010
- Alabama
How do I torque it down with a torque wrench if the shaft keeps spinning? I was using vice grips to keep it from spinning but I was just using regular wrench not a socket style wrench.
10-20-2011, 12:27 PM #6
seriously ?
04 C5 A4 Torch Red - sold
2009 CTS4 Ice Black - sold
2013 1500 Silverado Z71 - sold
02 Z/28 M6 Onyx Black All Options - Sold
2014 Caddy CTS4 - DD
2016 Silverado 2500HD
2020 Caddy XT6
2020 2SS Vert
10-20-2011, 01:42 PM #7Senior Member
- Apr 2010
- Alabama
What was the point of that response? I am just trying to figure out how to torque it down to spec. But in order to torque them down to spec you need to use a torque wrench and mine is a socket style so I can't hold the shaft with vice grips and torque it down.
Originally Posted by Danger731:2711535
10-20-2011, 01:46 PM #8Former Mopar Man
- Jun 2011
- Branchville, NJ
Just tighten the nut until the rubber gromet starts to push out a little. Don't crush it but don't leave it loose. just squeeze it a little. There is no torque specs for shocks.
10-20-2011, 01:49 PM #9Senior Member
- Apr 2010
- Alabama
Ok then I think I am good.
Originally Posted by 2002ssslp:2711559
10-21-2011, 05:18 AM #10
After 500 miles take another look at it to make sure it was tightend enough then you will be "good to go".
10-25-2011, 03:47 PM #11Senior Member
- Apr 2010
- Alabama
I have another question but with the front, I read through the guide on ls1howto and I am stuck on getting the ball joint on the spindle off. I don't have a pickle fork, anyone have a suggestion on something else to use and perhaps a better way to get it off?
10-25-2011, 04:35 PM #12Former Mopar Man
- Jun 2011
- Branchville, NJ
The correct way to break the ball joint lose is to use a pickle fork but you may be able to use a BFH on the BJ nut after you loosen it up. I would borrow one from a friend or Auto Zone or you can buy one from Sears or a parts store for about 12 dollars. Just be safe.
10-25-2011, 05:29 PM #13
10-25-2011, 06:35 PM #14Senior Member
- Apr 2010
- Alabama
Alright I guess I will buy a pickle fork tomorrow then. Sorry if I sound dumb with this question but I am asking because I am worried about breaking something. How am I suppose to wedge the pickle fork? I couldn't tell from the pictures on the guide on ls1howto.
10-26-2011, 05:32 AM #15Former Mopar Man
- Jun 2011
- Branchville, NJ
Pull the wheel, remove the brake rotor and leave the steering colum unlocked so you can move the spindle. Remember to use a jack to support the LCA and bang away.
11-09-2011, 12:24 PM #16Senior Member
- Apr 2010
- Alabama
I have another question my spring perch won't go on my new shocks, is there a trick to get it to slide down the shaft and onto the little ring? I pushed it on at the top and it's tight but it won't go any further. I tried tapping it with a hammer but it seems to fall off when I do that. Any suggestions would be great.
12-26-2011, 07:25 PM #17the cake is a lie
- Sep 2005
- hopewell jct, ny
black 01 red 73- 01 z28 and 73 z28
i know this is old but i just did shocks , struts , sway bar end links , tires ( Michelin pilots plus Z rated ) and a trans mount . i tightened it ( rear ) till it stoped turning with a vice grip on the top shaft . my KYB ... KYB Americas Corporation Shocks & Struts | Products | Gas-a-Just©.... rears came with 2 nuts for the top per side , as to "double nut" the top to prevent loosening ??? i also got the factory struts out without breaking the ball joint ??? . the top or the passenger side strut looked like it was submerged in the ocean . the nut was so rusted it had to be cut off with a wheel . obviously a spring compressor was in use . my car rides better than a new car !!! ive owned it since new (3 miles)
Preparing for a Rear Shock Install
By Naaman in forum Suspension and HandlingReplies: 1Last Post: 11-05-2016, 09:20 AM -
headers and shock install
By MIKEY'S 2002 TA in forum Southern MembersReplies: 0Last Post: 08-16-2008, 07:22 PM -
Shock Install for suspension nOOb
By Corvettekid82 in forum Suspension and HandlingReplies: 2Last Post: 07-28-2007, 07:19 AM -
Alignment after doing a spring/shock install?
By bad99ta in forum Suspension and HandlingReplies: 18Last Post: 06-20-2006, 09:30 AM -
shock install
By delinquent543 in forum Suspension and HandlingReplies: 4Last Post: 02-13-2006, 03:37 PM
