Results 1 to 17 of 17
    Member first01SS's Avatar
    May 2008
    Dallas, TX
    2001 Camaro Z28, Bolt-Ons
    My LS1 01 Z28 Dropped a valve (I think).
    Car is very lightly modified-- Lid, factory exhaust, stock heads and cam, 100 wet shot nitrous, which hasn't been used in over a year. After a long road trip (with cruise control and a few oh s*** WOT moments), drove the car the next few days with no issues. After a really short WOT run, pulled off highway, and found my engine was severely "knocking", no power loss. After stoping, and turning off the car, attempts to restart failed. (Engine locked). After having the car towed home, i used a wrench to back the crank off a bit, and attempted to start the engine. Engine started , still knocking, no issues. Oil pressure fantastic even knocking, never seen anything but royal purple, only premium fuel, everything is in great working order, except for the knock, there is no smoke from the tail pipe, no check engine lamp, all fluids ok. What are my options at this point? Should i be budgeting for a new engine? Rebuild what i have? replace heads? I'm terrified that my car with less than 80k original miles is done for, and i need to budget a replacement engine.. I don't post often, so be gentle, but i'm very desperate to get back up and running. Reliability and moderate power levels (300RWHP - 450RWP) are very important to me. I also would like to get fair MPG (23-30) if possible.. please help..
    East of Cleveland, Ohio
    99 WS.6 - Modified
    First off, stop using RP. It's not a good oil.
    But on to the problem, an engine locking up is not a good sign. You could drain the oil and check for metal. You could also pull the valve covers and check things there. Depending on how bad the knock is, and where it is coming from, it could be a number of things - varying from fairly easy and simple, to a full blown rebuild/replacement. But the engine locking up has me worried.
    May 2008
    Dallas, TX
    Engine idles smoothly when its actually running, negative the knock. It only locked up after i turned it off, and under the power of the starter. Once I backed it off a bit (reversed the crank about 1/3 turn) started right up.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    I would do what Knight said, and if there is nothing broken in the cylinder heads, I would check the starter as that could be binding and not retracting fully.
    May 2008
    Dallas, TX
    Just drained oil/no metal. (used a speaker magnet and a fine grease fryer/screen just to make sure. wife will get over it.) Should i start removing the valve cover? This occurred, FYI on the passenger side. I believe thats where the knock is coming from.
    99 WS.6 - Modified
    No metal in the oil is a better sign. I'd pull the valve cover/s and inspect things there.
    North Jersey
    2004 GTO M6
    Check for a broken valve spring or rocker arm and see if there are any needle bearings in the head. This sounds all too familiar.
    May 2008
    Dallas, TX
    The last bolt on the ignition coil rail is located far underneath the cowl. How can i get it out. I don't want to loose more fingers.
    North Jersey
    2004 GTO M6
    You could try a box-end wrench for added length to get to that bolt. It'll take longer than using a ratchet, but if you don't want cut-up fingers, then try the wrench.
    99 WS.6 - Modified
    Most people will not install the bolt again after removing it, either. Me being one of them I used a ratcheting box wrench to remove mine - a valuable set of tools to have.
    May 2008
    Dallas, TX
    Got the valve covers off. Checked all the valves; one spring seems to be excessively compressed. Removed the rocker arm, pushrod looks fine, valve still looks like it's there. None of the springs appear to be broken. Also, of note, once I removed the rocker arm, the spring immediately became uncompressed.
    Senior Member redbird555's Avatar
    Mar 2009
    pompano beach florida
    2002 Camaro Z/28 Pewter
    the valvesprings will depress quite a bit when the pushrod is on the top of the cam lobe so i'd say thats not the issue unless one is visible broken or wiggles in you hand theyre probably fine why not post a video of the sound so we can better diagnose
    May 2008
    Dallas, TX
    Well.. Is the an easy way to hook up the coils with the valve cover off so I can do that without having to reassemble everything and getting a decent view of the valve train while the engine is running? I can easily take a video post it.
    the cake is a lie twozs's Avatar
    hopewell jct, ny
    black 01 red 73
    01 z28 and 73 z28
    these motors are notorious for collapsed lifters from over revving
    How about a compression test? You can do that with the covers off. You can also pull the plugs and have a friend roll the engine over by hand to see if anything looks amiss.
    North Jersey
    2004 GTO M6
    Did any of the springs look like they were "bulging"?
    Aug 2000
    Indy
    Hate to add but air in the water pump makes a heck of a lot of noise. Did you do anything with the cooling system lately ? I'm at 101 K on my motor after doing wet shots and just drove here from San Diego with some good runs at times, these motors are strong. I used to power shift and I hit the rev limiter more than I'd care to admit.
  1. New valve stem seals the same for exhaust and intake valve?
    By JehalinTA in forum Internal Engine
    Last Post: 07-03-2011, 08:16 AM
  2. JEGS stud mount valve spr. compresor vs. Speeds valve spring
    Last Post: 05-30-2011, 05:16 AM
  3. D-Port Head Valve Upgrade - Big-Valve Performance on a Small
    Last Post: 04-20-2011, 04:10 PM
  4. Valve cover gaskets, Valve Springs, Timing Gasket
    By Dewman in forum Parts For Sale / Trade
    Last Post: 01-22-2010, 08:14 PM
  5. SS value has dropped?
    By totalkos in forum Camaro / SS
    Last Post: 11-08-2008, 06:42 PM
