Results 1 to 10 of 10
10-15-2011, 08:50 AM #1Senior Member
- Nov 2007
- Philly, PA
Black- 2001 Firebird TransAm WS6
Intermittent Radio and Window Problems
Wow, long time no post. This is my first time since the format changed. Anyway, here's my problem:
Occasionally while driving my radio will turn off (completely, not even showing the clock) and the windows will stop functioning. It comes back shortly after, is completely unpredictable.
Is there anywhere I can view a wiring diagram of the car (2001 trans am)?
In the fuse box I see a relay labelled "IGN", and I assume this stands for "Ignition". Both the radio and the windows begin to work once the key is in the ignition, before the car is started (there is another relay in there for the starter too, I believe). This leads me to believe that this relay could be a common source of both problems. Maybe there is some break in a wire causing the relay to drop out from time to time? Maybe the relay itself is bad?
Any suggestions or similar experiences?
10-15-2011, 10:04 AM #2None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Sounds like an issue with the BCM - Body Control Module. Check out this thread - http://www.ls1.com/forums/f50/bcm-le...control+module
10-15-2011, 02:17 PM #3Junior Member
- Sep 2006
- Georgia
red black- 98Z28
Look here for the missing pic Body Control Module Repair - Camaro Forums - Chevy Camaro Enthusiast Forum
10-15-2011, 09:41 PM #4
10-16-2011, 04:22 AM #5None Shall Pass
- Jan 2010
Didn't realize that. Sorry.
10-16-2011, 04:24 AM #6None Shall Pass
- Jan 2010
The steps are still good though.
10-19-2011, 02:48 AM #7
10-19-2011, 04:23 AM #8
10-19-2011, 06:24 AM #9Junior Member
- Sep 2006
- Georgia
red black- 98Z28
10-19-2011, 02:10 PM #10
Help: radio and window problem
By TransAmFanatic in forum General HelpReplies: 6Last Post: 08-01-2011, 04:58 PM -
fixed my intermittent windows, radio and locks
By Firebirdformula in forum Stereo and ElectronicsReplies: 0Last Post: 06-06-2010, 08:36 AM -
Intermittent Engine Problems
By harpjasm in forum General HelpReplies: 10Last Post: 03-22-2010, 01:28 AM -
Help: radio and window cahoots!!
By MSTrespctDAmuscle03 in forum General HelpReplies: 4Last Post: 08-31-2009, 07:12 AM -
Lights, Radio and Window Gremlins
By Flash00TA in forum General HelpReplies: 8Last Post: 05-22-2008, 04:54 PM
